Home > In Car Electronics (L322) > Avin 4 install in 2003 |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
Seeing as we lost all the pictures from Hylands excellent post, I did my own set and put them in a PDF for all to enjoy when I fitted the Avin 4 to my Range.
24th May 2019 7:51pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
To upload a pdf go into the gallery and your gallery, you can upload it there, then grab the link and make a post .
24th May 2019 8:16pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7647 |
That looks a cracking piece of kit.
24th May 2019 8:21pm |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 194 |
Very interesting, and hopefully the answer to my prayers. Watching with interest. |
24th May 2019 8:33pm |
Unplug the quad lock from the BM54, plug new loom into quadlock. Done ! really simple- All speakers working including sub as you are not by-passing the DSP amp No7 - 2003 V8 Vogue |
25th May 2019 9:14am |
MarkNL Member Since: 26 Jan 2014 Location: utrecht Posts: 43 |
2nd Dec 2019 11:30pm |
Lusen Member Since: 08 Apr 2020 Location: Skåne Posts: 2 |
Hi, all new here! Just ordered Avin Avant 4 for my 2003 L322 and found REwmer's guide, excellent write up. Although, I wonder if you pull the extension cable to the left in LHD cars as well?
8th Apr 2020 9:03am |
Installed my unit this weekend. Pro tip: unpin the Quadlock connector when pulling the cable up to the head unit, it's just way to big to fit.
4th May 2020 1:22pm |
16th Jul 2020 10:14pm |
harra123 Member Since: 13 Dec 2020 Location: Nairne Posts: 9 |
Hi Rewmer, any chance you have a photo of the rear of the head unit & connections in the back of the car please. I am having issues with no sound although everything else works.
13th Dec 2020 7:09am |
Hi Adam
13th Dec 2020 10:02am |
Not sure Mark, I will retry this coming weekend, thank you |
13th Dec 2020 7:56pm |
Hi Mark, I also had a question that Avin are still to answer. When I connect the extension cable to the main harness from the DSP amplifier, do I connect anything to the exposed port on the amplifier itself? Your help would be greatly appreciated, than you, Adam |
16th Dec 2020 9:48am |
