Home > Maintenance & Mods (L322) > Activating service intervals?
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
My car does not seem to have activated the on-board service interval "programme".
Can I enable this with the IID-tool? 2007 L322 3.6 TDV8 Stornoway
Post #522907 26th Jul 2019 9:20pm
S.Hafsmo
No way to make the car tell me when it wants to be serviced? 2007 L322 3.6 TDV8 Stornoway
Post #523277 30th Jul 2019 9:59am
not sure this is possible..any thing via the search function? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #523278 30th Jul 2019 10:13am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Same problem on our 2006 TDV8.
I asked on here a year ago, but nothing worked.
Lots of high tech systems on the car, but no ability to visibly see how many miles to the next service without using a Diagnostic Tool or calendar ! Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #523281 30th Jul 2019 10:21am
Baltic Blue
Try a reset by using the service/ test menu... instrument pack... service interval reset ?.
Post #523283 30th Jul 2019 10:25am
nearlee
Wales
My 07my tells me when it needs a service, so must be possible Remember:- amateurs built the ark
Proffesionals built the titanic
Post #523299 30th Jul 2019 12:38pm
Baltic Blue
I think my 2011 does, but I always reset it before it is due after doing a DIY service early.
All my service work is done when the weather man says we are in for a decent spell Rolling with laughter
Post #523311 30th Jul 2019 2:30pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
My 2012 does. I don't think it counted down though just popped up with 'Service Required' or similar. It hadn't been reset by the garage who did the full service (read oil change) when I bought it.
My indy wanted £45 plus VAT to reset it but after a lengthy Google I manage to do it myself. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #523312 30th Jul 2019 2:43pm
Weegie
AFAIK you can reset the service interval and when the service is due it pops up on the instrument panel but you can't access the information re time to run to next service.
It is such a variable depending on driving conditions and techniques etc that I would think it is not possible to achieve. John
GAP iiD BT
Post #523313 30th Jul 2019 2:53pm
Baltic Blue
I think you are both right..
I found out back in June....
https://www.fullfatrr.com/forum/topic51876.html
Post #523316 30th Jul 2019 3:00pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
From 2005 you'll need something like AutoLogic to re-set the service due time. Not sure what year that stopped being relevant. Mine is a 2006 MY and cannot be re-set via secret menu's or similar.
Last time they re-set mine it re-set itself at the beginning of each month i.e. 1st April it told me that the service was due April 2020. 1st May it told me the service was due May 2020. When I picked it up after the most recent work, my indy re-set it and it's back to normal. Says nothing until maybe a couple of months before it's due. I expect a warning of some sort in November to tell me it's due in January. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #523318 30th Jul 2019 3:18pm
Weegie
You can also do it with the Gap iiD for the 2006 on. John
GAP iiD BT
Post #523321 30th Jul 2019 3:46pm
S.Hafsmo
Attemptet an interval reset with the IID tool yesterday but just got "procedure failed" or similar. I'll try to do a print-screen when possible. 2007 L322 3.6 TDV8 Stornoway
Post #532835 1st Nov 2019 11:05am
S.Hafsmo
Post #532987 2nd Nov 2019 8:06pm
DrRob
Did you have engine running? It has to be engine off but ignition on Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #532988 2nd Nov 2019 8:08pm
