Home > Maintenance & Mods (L322) > The dredded oil cooler leak !!! |
ColinB139 Member Since: 02 Apr 2019 Location: Merseyside Posts: 1 |
2nd Apr 2019 6:49pm |
faz2kool Member Since: 11 Oct 2019 Location: Sheffield Posts: 42 |
Hi All
11th Oct 2019 12:31pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7650 |
Sheffield Prestige fixed mine. They have done loads since..... 2011 Range Rover Vogue SE 4.4 TDV8
11th Oct 2019 12:48pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4252 |
Green Oval in Leeds too. Take it to someone who knows these cars inside out. Not just any old mechanic. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
11th Oct 2019 12:51pm |
MJdronfield, thanks for the reply. Ive left a message with Sheffield Prestige. Did they replace the gasket on yours or the whole unit?
11th Oct 2019 2:27pm |
It was in a while as my oil cooler was cracked. They ordered one from Gordon Lamb and that arrived damaged, and I needed the coolant flushing out about 4 times to get rid of the oil......
11th Oct 2019 3:22pm |
11th Oct 2019 3:25pm |
Wow, for that price I hope its fully fixed. |
11th Oct 2019 3:38pm |
That was Feb 2016. No issues since.
11th Oct 2019 4:00pm |
I know this is not relating to an oil cooler leak however the specialist garage I took my car to sort the leak out also changed my front disc and pads. Please have a look at the pic of the front pads that they fitted. The pad.has fallen forward a d is grinding on the disc. |
11th Oct 2019 6:37pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16188 |
11th Oct 2019 11:38pm |
Thank you Craig. Brakes are messed up now |
12th Oct 2019 6:20pm |
So after a week being stood at my local indy... he diagnosed the leak to be coming from the sump and not the oil cooler. Has anyone ever heard of this??.
26th Oct 2019 12:24pm |
Yes, I have heard of sump gasket leaks.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Oct 2019 1:00pm |
