Home > Maintenance & Mods (L405) > Does anyone want a winch mount for L405? |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 |
wow that's awesome! |
19th Nov 2019 11:51pm |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
Mounting wise according to LR the bumpers mount identically and nothing has changed in the architecture from 2013 to 2019 in regards to the bumpers etc. |
21st Nov 2019 9:22am |
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 112 |
Excellent thanks Charles 2017 Range Rover Vogue SE SDV8 (with e-diff)
22nd Nov 2019 10:58am |
Updated picture.. took her to Tixover to test everything out, and ended up recovering a pickup truck that got stuck. So I made use of my Rhino snatch block and winched him out from round a corner
25th Nov 2019 7:27am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7797 |
Looks fantastic |
25th Nov 2019 8:43am |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Superb!
25th Nov 2019 2:14pm |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 |
Unnecessary quote removed
25th Nov 2019 8:10pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34949 |
thats a fair bit of extra weight on the front Charles, does it affect the steering? ... - .- -.
25th Nov 2019 8:59pm |
Everything was weighed and it totals just over 50kg + winch rope. But I opted for the synthetic dyneema rope, its stronger than the cable steel and far far lighter. I actually winched and recovered a ground out vehicle using a snatch block and it was incredibly effortless.
25th Nov 2019 9:14pm |
Any cooling issues with the light bars and winch in front of rads or is all ok ? |
25th Nov 2019 9:32pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Charles is that mega mount steel or aluminium?
25th Nov 2019 10:01pm |
No issues with cooling. Its absolutely fine, I guess the summer will be the true test.
26th Nov 2019 7:05am |
I am a bit nervous about the cooling impact in an Australian summer (40C plus). Especially towing. 2017 Range Rover Vogue SE SDV8 (with e-diff)
28th Nov 2019 7:32am |
You wont have an issue. Because the winch and mount only occupies the same surface area as the existing impact bar. So you loose no cooling. The reason cooling was asked in my situation was I have 2 light bars behind the grill so I am blocking airflow. But i have tested with the fans running and the draw is fantastic so I very much doubt there will be any issues at all. Especially if you have the AC on as the fans are always on with the AC and that will also keep things cool |
28th Nov 2019 8:52am |
