Home > Maintenance & Mods (L322) > EAS inoperative after battery died
pearsor19
United Kingdom 2003 Range Rover HSE 4.4 V8 Java Black
Having recently returned from holiday to a completely dead battery, I ordered and fitted a new one (thanks to this forum for advice on changing the battery) and sure enough got more or less every warning light and error message displayed on the dash. After driving a few miles they all went back to normal, but I forgot to do the old steering to full lock left then right trick. A couple of days later I noticed that there were no lights on the EAS controls, although there was no air suspension inactive messages in the display. I then tried doing the steering trick, but it had no effect - still no lights on the EAS controls and the ride height stays constant at the normal setting. Should I try disconnecting the earth lead from the battery, reconnecting and then immediately doing the steering wheel jiggle? I'm also going to clean the contacts in the towing electrics, although I suspect if it was down to this, I might get messages about failed trailer bulbs. Does anyone have any other suggestions? And finally any thoughts on the Faultmate FSR from Blackbox Solutions - is this a better buy than the EAS Activate device? My car is an '03 4.4 petrol HSE. And finally, finally, although I'm new to this forum, I have had great experiences with the Disco3 forum and can only thank all those with specialist knowledge who are willing to share it with inexperienced car mechanics like myself.
Post #53785 9th Mar 2011 8:19pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Yes, reset and try again. ie disconnect the battery for a while then do the full lock left to right after first start.
let the ecu's shut down before disconnecting the battery. 2004 black Vogue TD6
Post #53828 9th Mar 2011 11:00pm
pearsor19
Tried that this morning. EAS is still inactive,but I do at least get the message in the dash display now as well.....which has got me thinking. I've been meaning to take the car to my local tyre/exhaust shop to check out a phut-phut-phut sound, which is coming from the front lower RHS of the car (most noticeable near the wheel arch area), which I had thought might be a small hole either in part of the exhaust, or in the manifold gasket, HOWEVER...could it be a failure in the suspension air receiver, or the valve block or one of the airlines. Could it be the compressor itself, or is that further toward the rear of the car?
Thinking I should invest in a Faultmate FSR.
Post #53873 10th Mar 2011 10:52am
dan_uk_1984
Nooooo:
Wait a few weeks for the Rover All Coms software, it won't be locked to one vehicle.
Or buy the EAS Activate, a great piece of kit that you can just leave in the door pocket.
http://www.rswsolutions.com/index.php?opti...;Itemid=77
Post #53887 10th Mar 2011 11:34am
so, will this be a affordable bit of kit dan ,cant find much on the interweb about it... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #53889 10th Mar 2011 11:39am
dan_uk_1984
Mine is winging its way across the atlantic as we speak Wink
I believe the final price will be $295 (£182)
The latest video looks good:
http://www.rswsolutions.com/index.php?opti...;Itemid=50
Post #53900 10th Mar 2011 12:28pm
pearsor19
I was thinking about the EAS Activate as well, but am I right in thinking it only deals with the EAS ECU, whereas the Faultmate FSR communicates with ALL ECUs? I know the Faultmate is locked to only one VIN, but I only have one Range Rover (Although I do have the D4 as well). I would view it as an aftermarket upgrade to the car that would stay with the car even if I sold it. Much like I would leave a towbar on the car if I sold it.
The All Comms software does look good and seems to cover all systems with an ECU. Only drawback there is that I junked all my Microsoft based PCs in favour of Macs sometime ago. I would have to get a cheap netbook just to run the software.
Post #53907 10th Mar 2011 1:00pm
dan, are you one of the beta testers or is this a full retail version, also bit of a nob question, using this software if i clear a light error [led in halogen light] will this stay cleared all the time..
might be worth starting a new thread re this as i can see it being much talked about. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #53910 10th Mar 2011 1:08pm
dan_uk_1984
Beta tester.
With the bulb monitoring one turns the feature on or off. So you would turn the monitoring for that particular circuit off (not sure if this function is available in RAC yet, I will confirm upon delivery)
There is a rover all coms thread somewhere - I will start a new one when the thing arrives.
Post #53914 10th Mar 2011 2:00pm
nice one dan. Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #53917 10th Mar 2011 2:15pm
Reformed
Ive just got my EAS activate. Great simple bit of kit. Did get stopped at customs though who put another £36 import tax on it this side of America before they would deliver it! Will look at this other bit of kit to when its avaliable. Reformed
Post #54168 11th Mar 2011 10:57pm
