Home > Maintenance & Mods (L322) > DPF full 4.4 TDV8 2012
Page 1 of 6 123456>
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Hi guys
A bit of advice please just been to the local town for essentials (beer, wine, and steaks)
On the way back it starts smoking badly, and then DPF full warning comes up, drove it like I stole it the 6 miles home, no smoke anymore, but still have the warning up, says in the manual 20 minute drive at50 mph, cannot really do that In the current circumstances....
Any suggestions?
Post #550823 18th Apr 2020 4:37pm
DrRob
Do a search on here but intake leaks is where you should start before driving it again. Check the 4 doughnut hoses under the engine cover first, check intercooler hoses, check intake manifold for leaks. Ideally a smoke test machine is needed to help find it. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #550826 18th Apr 2020 4:45pm
it can take up to 20 mins drive...basically you need to run it until its hot enough to burn off the soot ....surely there must be a pharmacy 20 mins away.. Wink ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #550830 18th Apr 2020 5:32pm
20 min blast up an autoroute of your choice. Thumbs Up depends how strict the local gendarmerie are though I suppose. If they are likely to take you behind the small Peugeot van and give you a good flogging then maybe not..... Whistle There is nothing that can't be fixed with a hammer😜😜
Post #550837 18th Apr 2020 5:50pm
SFM
Any idea why it was smoking so much before the warning came on?
I wasn’t accelerating very hard at the time.
Post #550904 19th Apr 2020 6:23am
Mikey
6 miles is nowhere near enough a clear out the DPF
Post #550907 19th Apr 2020 7:23am
SFM
I appreciate that mikey
But what do you think the smoke was about, if they start a regeneration, do they smoke a lot?
No chance of Getting to a motorway, what if I drive in lower gear for 1/2hour
Bloody nightmare, as all garages here are shutdown due to the virus, so if warning light goes red I’m screwed
Post #550919 19th Apr 2020 8:45am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
This sounds a bit similar to what I have experienced with my own 2011 4.4 TDV8. I had some air intake leaks that were fixed by my local Indy, however just before lockdown the sudden plume of smoke came back and my DPF threw the amber followed by red warnings. I managed to clear the red and carried out a regent but haven’t been able to go any further due to the current restrictions. I’m hoping that once these are lifted I can carry out some more testing so will be interested to hear if you find anything in the meantime. You can read my latest issue in the link below.
https://www.fullfatrr.com/forum/topic54864.html
Post #550967 19th Apr 2020 2:23pm
SFM
Hi again
Well, as I cannot go anywhere at the moment, I thought that it would be a good time to order 4 new hoses, as everyone seems to think that this could be the problem causing the DPF full warning.
So...what are they actually called, and is it a simple job to do, do you have to remove the plastic plenum?
Where’s the best place to order them from?
Post #551069 20th Apr 2020 9:13am
SFM
Anyone?
Post #551114 20th Apr 2020 2:48pm
Dolphinboy
several members have posted their versions of replacement pipes. do a search and you will see several options Thumbs Up
https://www.fullfatrr.com/forum/topic52120...p;start=15
Post #551115 20th Apr 2020 2:51pm
jackie-o
Netherlands
partsnumber is 4 x LR056285 RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #551141 20th Apr 2020 5:58pm
GGX
United Kingdom 2012 Range Rover Westminster TDV8 Fuji White
I cleared by putting in sport mode and drive at 55mph for 20min on a duel carriage way, sport holding the gear down to it revs more generating more heat.
Post #551973 28th Apr 2020 4:16pm
SFM
Just an update
Car has been to my local garage since last Tuesday, changed the 4 short hoses on the plenum.
Cleaned everything.
My guy to it for a long run Sunday, but cannot get DPF to regenerate, don’t know where we go from here.
Post #553450 11th May 2020 1:52pm
Dolphinboy
1. Do you have an IID tool or OBC reader? Your soot reading should be less than 28g as above that it cannot be force regenned by a dealer. It will have to be cleaned.
2. What is your "fuel in oil" value? The engine puts extra diesel into the system in order to raise the temps in the DPF in order to force a regen. If regen does not occur, then the extra fuel is unburnt and gets into and dilutes the oil system and I believe this can hinder further regens (catch-22). The upper limit is 7.
I had a reading of 12!! so changed my oil to get the reading back to zero and managed to get rid of the RED DPF warning on my own with IID.
3. Check the voltage on the Rear DPF sensor. I can't remember the correct Voltage reading (someone on here will remind me hopefully) but it should be less than c. 0.8V (please confirm somebody?)
4. Check EGR valve working correctly.
5. How much fuel in tank? Regens only occur if there is at least 1/2 tank left (I think - not sure on exact level)
Post #553451 11th May 2020 2:21pm
Page 1 of 6 123456>
