Home > Maintenance & Mods (L322) > Fuel Gauge erratic
Page 4 of 5 <12345>
ABY
United Kingdom 2010 Range Rover Vogue TDV8 Baltic Blue
So I attempted to fix my dodgy fuel gauge this week - When I fill full after a while it will suddenly start reading 1/4 full ! Bit of a shock the first time it happens about a couple of weeks after purchase. I thought Censored these things really guzzle am going to have to start extending the mortgage ! Then a few click on here and I relaxed a bit.
Definitely just cut the carpet under both brackets - much quicker.
You will need a 10mm socket/spanner to remove the cover plate ( I just removed the drivers side round plate )
This is what you will see (Vogue TDV8 2011). Use a rachet strap on to the front seats to hold back the carpet and insulation.
I used a hammer and flat head screwdriver to remove large round lid ring (tapping at an angle) n.b. Loosey lefty.
Here is what you see. The black clip is half way down the pipe/ wire loom leading to the pump.
This is the culprit
I used a crockspanner to hold the wires up so I could perform the operation.
New connectors installed. When I put this back I cable tied it to the rest of the loom leading to the pump which is situated at the bottom of the tank.
Not much mess from diesel when removing the main hose fittings and top housing. It helped covering everything with chopped up black bin liners and lots of gaffer.
The job took me about and hour start to finish.
Good luck Thumbs Up 2010 3.6 TDV8 Vogue
Post #552818 5th May 2020 5:47pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Thanks for the write up ABY
Similar to mine only I stopped before venturing down the loom to find ther plug
Are you able to report it fixdd the issue completely..? I may well get out andf do this last step..!!
Thx Ash
2016 SDV8 AB
Post #578613 6th Jan 2021 8:48am
ABY
yes all working fine 8 months on. Thumbs Up 2010 3.6 TDV8 Vogue
Post #578626 6th Jan 2021 10:55am
comports
Thumbs Up good job Ash
2016 SDV8 AB
Post #578629 6th Jan 2021 11:07am
comports
Update - As it was bugging me, I nipped out at lunch time and did this fix - took about 45 minutes but that included me having to fish for the black wire after I had cut it but before I had chance to connect it up again..!
Would have been ok but I only put £95 deisel in ther last week and only driven 26 miles on a full tank.... To say it was high was an understatement.
All done now though so fingers crossed.!
Thanks for the detail ABY - pushed me that last bit to do it.! Thumbs Up Ash
2016 SDV8 AB
Post #578721 6th Jan 2021 7:34pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Got here after suffering from "Fuel Empty" message and guage dropped to empty (I only filled her up last week). First thing came to my mind was a stuck float so stopped at the garage to fill her up.. still no luck.
Searched the issue on the forum and landed here which put my mind at rest as some good examples and well explained steps have gave me the courage to do the fix.
Few questions:
1- do I need to wait until the fuel level is less than half or quarter?
2- do I need to replace the connectors at both sides?
3- do these wires float in diesel or are they protected?
4- where do you get the connectors? And what type?
Please advise Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #580029 16th Jan 2021 7:14pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
The less fuel the less mess you're likely to make. I had my arms deep inside the tank. I guess it would be doable with more fuel but less pleasant!
Not necessarily but you may as well ah if ones gone it's probably only a matter of time.
Don't think they float. They just sit in the diesel.
I didn't even try and replace I just soldered them together. But IIRC you can just cut off the old connectors and replace them with an alternative. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #580036 16th Jan 2021 8:14pm
scotcruz
Thanks Mike.. gonna drive about to a) allow the fuel level to go down and b) the weather to get better.
Goes without saying but I assumed you soldered on the bench? I dont plan to take it all out so don't think soldering would be an option if I am looking to do in situ due to being so close to diesel. Current:
Past:
Post #580038 16th Jan 2021 8:37pm
comports
MikeO
It’s doable with a full tank but you might get diesel hands if it’s too full - the work can be done in the wires outside the tanks but be careful not to pull too much. You are basically looking to cut the black plug off and connect the wires directly (black to black and blue to blue)
I used an inline crimped connector but any will work. The wires are very thin so I guess it’s resistance voltage only and tou only need small connectors - they will just sit in the tank if diesel anyway. Ash
2016 SDV8 AB
Post #580042 16th Jan 2021 9:02pm
scotcruz
Does anyone have the Bulletin LTB00566v6 in English? I can download the German one but the Disco link to the English one isn't working.
Thanks in advance Current:
Past:
Post #580097 17th Jan 2021 12:33pm
scotcruz
OK, had a go at it today.. took just over 2 hours as I took the pump out and soldered instead of crimps (as per Mike's advice) finishing it nicely on the work bench.
I got hold of the bulletin in English which was quiet handy (will upload it when I am on my laptop)
1- I emptied the tank with a siphon pump, had about 55 litres in. (Glad I did this as it was less messy)
2- undid the passenger side first
3- then undid the driver side (the spring on the pump fell in the tank as the plastic at the top had a cracked (no problem, all sorted with glue)
4- cut the black plug for the blue and black wire at both the pump end and the passenger side sender end.
5- as the bars for the springs pushed into the pump, I opened it up and cleaned the mesh (was not too bad for 10 year old tank and pump opened for the first time)
6- soldered and heat shrinked nicely,
7- checked the resistance on both sides (mine was 56 ohms at empty and 1000 ohms at full). Sweet, we are now ready to put everything back in
7- start with inserting the pump first, then the passenger side sender
All done, guage now working.. (thanks to the clear guidance and advice here)
Cheers folks.. well chuffed with the job.. so much satisfaction doing it yourself. Current:
Past:
Post #582635 7th Feb 2021 12:06am
MikeO
Thumbs Up 2016 Skoda Octavia VRS Estate
Post #582637 7th Feb 2021 12:16am
Bingo_123
does this fix has to be done both sides or just passenger side ?
Post #594144 13th May 2021 3:16pm
rjff
Bingo
Here's a link to the TSB for the job.
https://static.nhtsa.gov/odi/tsbs/2014/SB-10102562-9340.pdf
It refers to up to three connections. When I did mine I took both the units out but cannot remeber if it is necessary to remove both to do the TSB. The reason for removing both was the main pump "bridge" holding the unit in had failed allowing the two pillars to drop into the unit and the pump fell over. I took both out and repaired the bridge and checked the secondary unit at the time as well as doing the TSB
HTH. Cheers
Richard
Gap IIDBT
Post #594156 13th May 2021 4:50pm
scotcruz
Doesn't need to as long as you can identify which side needs done.. my view was I'm there.. May as well do both to avoid any issues Current:
Past:
Post #594157 13th May 2021 4:51pm
Page 4 of 5 <12345>
