Home > Technical (L322) > OBD Scanners/Readers Info |
With the increasing complexity of cars it is nearly impossible to perform even a basic fault diagnostics without some way of querying the information stored in the car's ECU.
12th May 2009 11:34pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Can I ask which OBD you went for? Also, I notice you had data from your P38, have you tried it on your L322?
12th May 2009 11:59pm |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 |
Dan are you only interested in reading the data rather than reading and resetting the DTC's |
13th May 2009 6:56am |
I'm very tempted to get the Bearmach one |
13th May 2009 9:08am |
Steve, I went for one very similar to This . (eBay links stop working after a while, just search for "USB OBD") Yes I have used it on the L322, quite a few times when I was tracking down and resetting codes due to my leaky PCV system, like I said, I wouldnt be without it now. |
13th May 2009 9:51am |
Any one you buy should come with good instructions, generally they are fairly simple. DigiMoto I find has the best user interface. Sometimes you have to assign the com port to the USB manually (usually if you plug it into a different port than the one you installed it on) but this isn’t as daunting as it sounds! |
13th May 2009 10:07am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6356 |
Great post Dan, thanks for clearing the mist! Discovery 4 HSE
13th May 2009 10:13am |
Ken, As any OBD Reader's main purpose is to read and reset the Error Codes or Diagnostics Trouble Codes that is my main reason for having one, but as I also wanted to be able to read extended data that's why I bought and would recommend the USB one. Dan |
13th May 2009 10:16am |
its good having an unbiased view on this subject if you have read the D3 thread you know what I mean
13th May 2009 10:23am |
Which Bearmach one would that be? U got a link? |
13th May 2009 10:38am |
Cheers Dan,
13th May 2009 6:23pm |
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 |
The price has dropped then for the USB ones. Some of the ELM chip based USB units were upwards of £80 only last year and the software (usually shareware) was partially in Hungarian.
14th May 2009 9:13am |
Lets face it, they've always been made in China for 50p its just we've been paying a disgusting markup! I think I paid about £25 for my ELM327? from China. |
14th May 2009 9:50am |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 |
Hi,
14th May 2009 5:06pm |
