Home > Technical (L322) > rear view camera not working
uae
United Kingdom 2006 Range Rover Vogue SE Td6 Alaska White
Hi all
need some advice, i have a range rover 2006 Vogue se when i drop it into reverse the camera don't come on, also i had a icon on my screen for the tv and rear headrest controls they have disappeared too..
can anybody help on this topic?
thanks immy Notts
Post #52872 4th Mar 2011 12:34pm
Sad Confused
Last edited by Gazellio @ Prestige Cars on 18th Mar 2011 6:10pm. Edited 2 times in total
Post #52878 4th Mar 2011 12:47pm
done a search? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #52879 4th Mar 2011 12:48pm
http://www.fullfatrr.com/forum/topic4479.h...rse+camera ====================================
Post #52881 4th Mar 2011 1:04pm
uae
Yes try to look on the net but no joy...
i have been told that it may need to be programed back up to the car not sure if thats true but the range rover dealer say they would need it for a few days, they charge about £150 an hour i think thought i try to ask about first to see if its a simple thing to do to get it working again.. Notts
Post #52926 4th Mar 2011 4:30pm
uae
Hi mick
it dont really tell me much about my issue as mine dont work.. if i co into diagnose moe via the screen it shows the camera working, the self test comes up with no tv signal.. if you go to the test moe it come up with tv,phone,rse,dvd not fitted..
thanks Notts
Post #52928 4th Mar 2011 4:35pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Have you checked the inside of the rear for dampness/ water in the cubby with all the electronic toys? It may be that condensation has ruined the unit. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #52934 4th Mar 2011 4:59pm
uae
Hi Tim
yes i have had a look it is all dry there,
thanks Notts
Post #52954 4th Mar 2011 6:56pm
BrianC
ive just done the self test on mine and the camera doesnt come on when you select reverse, but in the self test mode it shows the reverse camera working but below it says car configurator not fitted .there is a companion camera shown as fitted and it says configurator fitted ? do i need to plug in computer to get it configurated
Post #53229 6th Mar 2011 10:02pm
uae
Hi got the same problem
i have been told by the range rover dealer it has to be reprogrammed in again..
but dealers always say one thing and then it ends up to be something else..
mine is going in to range rover end of this month.. so if you don't sort yours out by then ill let you know how i get on...
thanks immy Notts
Post #53237 6th Mar 2011 10:49pm
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
does the whole rear cam screen disapeared?
When I put into reserve it comes the screen up. But! this screen is black!! sometimes there is a picture coming on.. But most time its black. Any ideas how to dismantle everything and check connections?!
regards
Phil
Post #55454 18th Mar 2011 6:05pm
uae
Hi mine don't work at all it only works in diagnose mode..
if i was you check the rear camera first at the boot end.. to check behind the head-unit you have to remove alot, your side heater vents all the screws that you see on the top, there 2 screws under the heater vents, then you have to pull the dash cover towards the back of the car and lift up.. when you remove that you have about 6 screws that hold the head-unit in...
let me know how you get on.. Notts
Post #55460 18th Mar 2011 6:39pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
finally working
After approx 9 months of an intermitant black screen it finally works. Had the wiring checked by LR during a service (at no charge!), they diagonsed the camera module. Ordered one in the UK, delivered to a mate. Visited last friday, rear-spolier off un-plug old one - place new one and hey hey it works. Took the ribbing about not bothering to look behind when reversing etc etc.
Also discovered that my high-level brake light had 'unglued' - will replace it when he visits over here!.
Post #55557 19th Mar 2011 9:09am
uae
Re: finally working
Hi
on mine it works now i had the software update done, my head-unit forgot it had a rear view camera just got the car back today,
thanks Thumbs Up Thumbs Up Thumbs Up Notts
Post #55638 19th Mar 2011 7:40pm
Good to hear have to get mine sorted ........... Thumbs Up Thumbs Up ====================================
Post #55639 19th Mar 2011 7:43pm
