Home > Maintenance & Mods (L322) > Rear Brake Disc's
Rear Brake Disc's
Right its payday and I've got my bonus so the FFRR is getting a new set of anchors all round. My rears are very shot and i now have a band round the outside of corrosion/scale. its as if the pads aren't touching the full braking surface. Could someone with the 4.4 petrol let me know if this is correct or has some spanner put the wrong pads in?
Anyone know of any good places for disc's and pads. Quite fancy some of the discs with the anti corrosion coating. i had EBC discs on my VX220 and they were awesome. would like them again but cant see almost 3 tones pulling up as quick or noticing any real difference in stopping power.
Post #56691 25th Mar 2011 7:11pm
done my fronts recently and got them of ebay, discs and mintex pads for around £70 delivered, rear combos are slightly cheaper.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #56692 25th Mar 2011 7:16pm
Did you use standard discs or up rated?
Post #56694 25th Mar 2011 7:38pm
just bog standard , and they work really well .. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #56700 25th Mar 2011 8:17pm
hoppy_70
England 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Brakes international are pretty good value. My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #56706 25th Mar 2011 8:59pm
these are the fronts ones i got ...
http://cgi.ebay.co.uk/RANGE-ROVER-L322-FRO...5d27270e95
and the rears i'm getting soon...
http://cgi.ebay.co.uk/RANGE-ROVER-L322-02-...45e990c7da ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #56708 25th Mar 2011 9:06pm
johnatandy
England 2005 Range Rover Vogue 4.4 V8 Oslo Blue
Re: Rear Brake Disc's
Mine have got that corrosion ring on the rears too, must be another one of those 'common' problems Whistle
Post #56711 25th Mar 2011 9:11pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I recently (uprated) the discs and pads all round on my P38 and my CLK and wondered about doing it to the FFRR as well. I just got slotted/drilled/grooved discs all round on the P38 and they work great and look good as well.
I got a set of Mintex discs n pads. They seem great so far..! Ash
2016 SDV8 AB
Post #56726 25th Mar 2011 11:44pm
slim_sane
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
+1
Post #56739 26th Mar 2011 7:29am
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
when mine need replacing i'll be going for Brembo drilled/vented discs and Brembo pads
some decent prices on fleabay and i've checked that they are genuine Brembo parts
Post #56756 26th Mar 2011 11:46am
Rear brakes don't work as hard as the fronts, therefore they tend to build up that rusty ring around the edge. Take the vehicle for a drive at 70mph and when there is nothing behind you slam on the brakes hard, do this a few times and the rust should clear off, it will also deglaze the brakes making them more efficient.
Post #56758 26th Mar 2011 11:51am
make sure they are the correct thickness nick, they might be different because of the brembo callipers.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #56762 26th Mar 2011 11:58am
nick h
thanks Stan - have checked and they are specifically for the 4.4 V8
Post #56772 26th Mar 2011 12:19pm
