Home > Technical (L322) > New Owner - Errors and faults |
Navydoc Member Since: 01 Jun 2014 Location: Perth Posts: 69 |
You must have been other combustion gases present too as Carbon Monoxide has no odour or taste which is why it’s so dangerous 👍 |
7th Nov 2020 11:17am |
Ashmyster79 Member Since: 07 Nov 2020 Location: Essex Posts: 240 |
Oh definitely. The smell I couldn't even describe it. I guess it was like having the exhaust re rooted back in to the cabin. I drove it home 2-3 hours had a mad headache. I survived though. Definitely going to keep the tester in the car for a while but the smell has totally gone!!! |
7th Nov 2020 11:24am |
So just stated up and got a couple of errors on the dash. Plugged ODB in and it is still showing the misfire on cylinder 3-5-7 that I had yesterday before the Sparks were replaced. Any ideas of why the ODB would be showing these errors and what the cause would be. New sparks should cure this right?? |
7th Nov 2020 11:57am |
We’re the faults cleared?
7th Nov 2020 3:55pm |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
i think the best thing would be bite the bullet and replace all coil packs the time it takes to remove all the covers to get to the plugs just replace the coils as well if 3/5/7 are down it is not going to be long be for the rest fail . it is like people replace one side like ball joint track rod end etc you just as well replace them all . job done new vehicle purchase
7th Nov 2020 4:28pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
With a fuel pump changed, spark plugs changed, and a remap done, I'd almost feel like there is too much change to clearly understand what is causing it.
8th Nov 2020 9:46am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1273 |
Because anyone with half a brain or a modicum of observant skills does not need a computer to inform when a tyre is underinflated |
8th Nov 2020 10:08am |
I will bow to your superior skills that when looking at a tyre you can just see that a front right is 2PSI less than rear left
8th Nov 2020 10:21am |
They are good when they work. When they don't the blinking error gets annoying. True you can't tell visually if it's 1-2 psi but you can when it is totally flat. I had this on my Bentley GT. £1000 to put 4 batteries in tyres was a bit steep so just let the display show the error. To be fair I don't know if the tyres/wheels have the batteries in so will find out when I do a tyre change at some point. For now it will be hidden behind a dot of black masking tape 😉
8th Nov 2020 12:21pm |
Thanks for all the tips and info. I did think coil packs too but wasn't expecting to pay out a grand straight off. My own fault I guess. The smell is like going through the Blackwell tunnel (if anyone has) in rush hour that's what it smells like in the car. Sparks changed the smell has significantly reduced so it might just be in the fabric of the car so to speak. Needs the windows open.
8th Nov 2020 12:25pm |
Yeah . Personally I would first want the remap removed and get the car to stock just to eliminate the remap. I would only put one on by those who can actually make them and not just download from the internet, and then only on a good working car. Just a thought. |
8th Nov 2020 12:31pm |
Yes so cowboy seller said
8th Nov 2020 1:31pm |
Get it on some ramps, get them to check for exhaust and EGR leaks (pretty sure it has some even though petrol) round the engine bay and underneath.
8th Nov 2020 1:39pm |
The last one I had few years back had a lambda sensor issue so was an easy replace and the error code suggested that so was an easy fix. You are 100% right though it should never be able to come in the cabin. When fans were on it would come through them I am sure.
8th Nov 2020 3:01pm |
