Home > Maintenance & Mods (L322) > Which Engine Oil |
Gunni Member Since: 13 Jan 2018 Location: Dorset Posts: 16 |
It depends if you have a dpf. I use that oil in mine with no issues, mine is older but same engine. Jon
26th Jan 2021 8:54pm |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 184 |
Hi Gunni
28th Jan 2021 10:50am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
The 3.6 is highly unlikely to have a DPF. Careful.
28th Jan 2021 11:33am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16185 |
Did you mean a DPF? The 3.6 in the UK spec didn't get a DPF sir... Standard fit came along with the 4.4 TDV8 and yes that is 100% CRITICAL you use the correct oil in the 4.4 TDV8 |
28th Jan 2021 11:41am |
My mistake as I was thinking of the 4.4v8td engine. Surprised that the 3.6 wasn't fitted with a dpf. Well spotted by the others: must get out more!
28th Jan 2021 12:08pm |
Tomc Member Since: 15 Oct 2020 Location: Belfast Posts: 36 |
Many thanks for the information, so in a nut shell my 3.6 has no DPF, should i use C1 type just in case or not really needed.
28th Jan 2021 1:28pm |
Throw your rego into the Opie Oils website and it will do the rest....
28th Jan 2021 2:29pm |
The 3.6 in certain market places was fitted with a DPF I believe... California springs to mind 👍 |
28th Jan 2021 2:43pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3198 |
My 3.6 doesn't have DPF . I went on the Opie website which confirmed the vehicle details of my car and recommended C1 which I am using. I went for the Millers 30W5. Am perfectly happy with it if that helps you. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
28th Jan 2021 3:37pm |
Perfect. Thank you for you help everyone.
28th Jan 2021 3:59pm |
