Home > Maintenance & Mods (L405) > Adding Timed/Remote Climate to 2017 model - it can be done |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35217 |
put into the wiki next to the 2014 version..thanks. ... - .- -.
7th Jul 2021 12:46pm |
spbee Member Since: 25 Jul 2021 Location: Cumbria Posts: 34 |
'Antenna for receiver (a glass mount 433MHZ antenna with Fakra I type connector will work)'
2nd Aug 2021 7:30pm |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 217 |
Unfortunately I can't remember where I got the antenna from. It doesn't need to be a type I connector, a type Z (universal) will also do the job. I used a type I as I wanted to to match the connector on the receiver.
2nd Aug 2021 8:23pm |
great TYVM will grab one with a Z end (i forgot they were universal !) and have a crack at it |
2nd Aug 2021 8:25pm |
Last question i promise!
2nd Aug 2021 8:27pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16257 |
Great work sir |
2nd Aug 2021 11:29pm |
Connector body is Landrover part no YPC915820, it is made by TE Connectivity (Tyco) I think part number 1355082-3 but most suppliers seem to only do them with minimum order 1000+ The connector inserts I used were ones I had at work that fitted, I believe the Tyco part number for these is 5-928999-5 for wire size 0.25-0.35mm2 or 5-963715-5 for wire 0.3-0.5mm2 |
4th Aug 2021 3:32pm |
brilliant thanks for your help.
4th Aug 2021 5:12pm |
All done and tested on my 2015 , did all the CCF changes using a GAP tool.
9th Aug 2021 1:14pm |
this also works for pre 2017 vehicles |
3rd Sep 2021 3:08pm |
