Home > Maintenance & Mods (L322) > Second Battery Install |
Certainly no issues yet - ie the car hasn't gone into electrical melt down.
2nd May 2011 10:21am |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
so how have u wired it all in dan would u be able to put it on here where you connected everything
2nd May 2011 1:57pm |
If you can wire a plug then you can do this mod. As long as you can cope with positive and negative cables you'll be fine, life's made easy with them being Black and Red! You only need basic tools and there is no cutting or splicing of the vehicle wiring. You'll need a 10mm socket, a crimp tool and some wire cutters. This is where I ran my cables:
+/- Points by d86cfv, on Flickr |
2nd May 2011 3:27pm |
Turbo Tony Member Since: 06 Apr 2010 Location: London Posts: 243 |
Researching my first Range Rover purchase |
3rd May 2011 8:22pm |
First issue with having a second battery today - I didnt tell the mechanic I had a second battery, so when he disconnected the main battery to change my steering column the car stayed powered up as if by magic!
5th May 2011 6:12pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 428 |
i am just contemplating a second battery in my 10MY tdv8.
question is VSR why dual voltage? so it senses both ways? plus suppliers? any recommendations? i was thinking of Durite range: 12V 140amp Durite Intelligent Voltage sense Split Charge Relay. http://www.ebay.co.uk/itm/12V-140amp-Durit...3a99b2cdd1 plus cut off like - http://www.ebay.co.uk/itm/DURITE-0-605-01-...35d3fcb9b1 the other way would be to get a premade kit made up and then use sections from it as fro something like this http://www.ebay.co.uk/itm/251730840815 at £64 could save some effort buying extra cables, crimps and fuse holders/fuses. thoughts. Cheers James |
7th Jan 2015 10:04pm |
7th Jan 2015 10:43pm |
anyone tried the 2nd battery install with a VSR on a vehicle with pyro with the aim of running it as my post above? Cheers
25th Jan 2015 4:29pm |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 |
Has anyone done the dual install in the boot as per this thread and still use the removable tow ball in the standard holder? |
22nd Apr 2015 7:52pm |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 |
having the dual battery set up sorted in the td6 and guy has suggested a led battery meter will this do any advice welcomed cheers http://www.ebay.co.uk/itm/12V-Marine-Boat-...1715913311 |
28th Dec 2016 8:23am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7762 |
Given the size of the tow ball vs the size of battery that can fit into that compartment, I would have thought it easier to find a new home for the tow ball...... |
28th Dec 2016 10:38am |
