Home > Technical (L322) > 4.4 TDV8 2012 running issues |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
I would get the iid tool on it as soon as poss, but if needed to be driven in meantime, you should take it for a cruise, to allow the dpf to clean itself. so, get on a motorway/carriageway, and cruise it for 30 mins, low speed, as long as you maintain more than 35mph. the oil on tailpipes could be a not completed previous 'burn' OR 'regeneration'. if you continue to drive it too slow, with the amber light, you will go to red warning, and more grief and limp mode. |
8th Sep 2022 10:13pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1366 |
Most likely that you've got an intake issue. Please search the forum, as there's hoards on this topic. You mention the right air box so, take it apart and the ducts and have a look then follow the steps below? The IID is unlikely to pick up smaller leaks so, visual inspection is your best bet. Copying and pasting from similar posts over the last week:
8th Sep 2022 10:23pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2759 |
Your last sentence would indicate a blockage on the air intake. Either a very dirty air filter or something blocking the intake to it. 2012 TDV8 Vogue (L322) |
9th Sep 2022 7:53am |
Jamesonfox Member Since: 06 Sep 2022 Location: Wales Posts: 22 |
Thanks for the assistance so far.
9th Sep 2022 7:57pm |
The 4.4 TDV8 is a pretty bulletproof engine and will weather these issues so long as you get them sorted.
9th Sep 2022 8:10pm |
Nothing out of the ordinary there. That broken coolant joint needs fixing ( expensive part or DIY solution) and seal the main TB joint as said but still not sure how the air box to intake hose is collapsing when revving the engine under no load unless it’s blocked or has a restriction upstream so maybe worth checking this again. 2012 TDV8 Vogue (L322) |
10th Sep 2022 7:48am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 663 |
This was mine, incredible how much crap gets in there.
10th Sep 2022 8:31am |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 274 |
I ended up buying the whole LR assembly when I broke the little coolant hose connection, but there are fixes on here if you search the threads. It’s the most incredibly brittle part considering it’s location, just another example of Land Rover nuance I suppose - occasionally I get a little bit annoyed that LR can make such fantastic vehicles, yet they always manage to have a few parts that are so bad or stupid, you have to wonder who signed off on it. Then I get over myself, buy the part and get on with it. |
10th Sep 2022 10:16pm |
To be fair it's probably a Ford part / design. 2012 TDV8 Vogue (L322) |
11th Sep 2022 9:31am |
The MAP sensor, intake manifold and throttle have been completely stripped, cleaned and reassembled, with 4 new hoses to the "donut" and tape on the throttle body. With so much gunk, I’d be surprised if anyone ever opened it up before my tenure. Thanks for the heads up, garyRR.
11th Sep 2022 2:32pm |
Radio silence… |
13th Sep 2022 11:09am |
Low oil level - when was it last serviced?
13th Sep 2022 11:28am |
Was the oil low because it was last serviced a while ago or because whoever serviced it didn't put the correct amount in?
13th Sep 2022 2:01pm |
So the beast previously had an oil leak from the oil cooler. However, I can't see any reference to the garage that replaced the cooler, topping up the oil. That might be why its level was so low.
25th Sep 2022 10:22pm |
