Home > In Car Electronics (L405) > Incontrol app frozen/not speaking to the car |
jumpin mouse Member Since: 28 Feb 2016 Location: North West Posts: 222 |
How annoying. I can only think to delete the app, reinstall it and log in again.
5th Feb 2023 8:53pm |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 378 |
thanks JM, ive deleted and reinstalled the app with no joy. I'll ring LRA tomorrow. They may be able to help with the SIM not working too. First time FFRR owner |
5th Feb 2023 9:03pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1093 |
I had similar issue, the car was showing parked at the last service station I had visited 50 mile away, and could not get it to work. Next day it was the same.
5th Feb 2023 9:58pm |
cheers Kot, I don't have a code reader (yet), surely LRA will be able to assist with any of that. It shouldn't have any issues with battery condition, its had some decent runs (including a 2 hour run today).
5th Feb 2023 10:13pm |
Arch
5th Feb 2023 10:49pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
@Kot:
5th Feb 2023 11:20pm |
I love my Range Rover.
6th Feb 2023 11:49am |
Hi Arch:
6th Feb 2023 7:15pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1657 |
I've had / am having the same issue.
6th Feb 2023 8:34pm |
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 37 |
Hi comports, it could possibly be faulty telematics control unit. There are a few thing you can do to reset it and see if will reboot. Locate unit ( normally behind n/s c pillar trim) unplug the unit and remove the internal battery. Give it ten minutes and refit it, clear all dtc,s. This might then boot up. Also uninstall and reinstall the app and follow the sos button reset. If after that it still refuses to work May need new unit ( which were and are still possibly on back order) |
7th Feb 2023 2:46am |
Thanks M11
7th Feb 2023 12:29pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
the location is in the WM,
7th Feb 2023 12:39pm |
Thank you Stan
7th Feb 2023 12:59pm |
Hi, not sure on your reg number to check but found this if helps. ( or not as the case maybe )
7th Feb 2023 3:02pm |
