Home > In Car Electronics (L405) > Incontrol app frozen/not speaking to the car
Page 1 of 3 123>
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
As title really, it has worked fine for the last three weeks since I collected it, I went to the tip yesterday and the boot was open for 20 minutes, the app sent me a message notifying me the boot was open and the app has been stuck at this point since. No journeys are being recorded and no notifications when in guardian mode and I open doors etc.
I've logged off all accounts and back on again, had a long (10sec press) of the LRA button in the roof console but nothing.
Any ideas or does it need intervention from LR? First time FFRR owner
Post #655718 5th Feb 2023 8:03pm
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
How annoying. I can only think to delete the app, reinstall it and log in again.
Otherwise get on the phone, I have found then to be helpful in the past.
Post #655726 5th Feb 2023 8:53pm
Arch Stanton
thanks JM, ive deleted and reinstalled the app with no joy. I'll ring LRA tomorrow. They may be able to help with the SIM not working too. First time FFRR owner
Post #655729 5th Feb 2023 9:03pm
Kot
I had similar issue, the car was showing parked at the last service station I had visited 50 mile away, and could not get it to work. Next day it was the same.
I charged the car battery and also did a DTC check and there was a telemetric fault, once reset and cleared, and with a charged battery it started to work.
I use Autel AP200 https://www.autelstore.co.uk/wholesale/aut...anner.html
Buy a CTEK as well, you will be glad you did. 2018 SE SDV8 4.4 Byron Blue
Post #655739 5th Feb 2023 9:58pm
Arch Stanton
cheers Kot, I don't have a code reader (yet), surely LRA will be able to assist with any of that. It shouldn't have any issues with battery condition, its had some decent runs (including a 2 hour run today).
I'm up early tomorrow and the remote cabin heat would have been nice.
Edit - Autel ordered. First time FFRR owner
Post #655745 5th Feb 2023 10:13pm
Kot
Arch
If you have warranty then of course your dealer can fix it.
I also have warranty, but usually they cant give out a next day/week appointment, usually its for 3 weeks in the future, I couldn't wait that long Rolling with laughter so i used the scanner and TCU fault was detected, and then erased, it cleared and it worked for me never been back since Thumbs Up
I now have a different Incontrol issue, and now need a VSS update (Vehicle shared secrets) but they cant do it until 27th Feb.
Yes gremlin, my batteries charged Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #655750 5th Feb 2023 10:49pm
Gremlin500
@Kot: Razz
Wink
Very Happy “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #655755 5th Feb 2023 11:20pm
Arch Stanton
I love my Range Rover.
It made me get into a cold car this morning because I couldn't use the remote pre heater as the app had locked, I had a trip into Manchester and back, (lovely relaxing drive btw) and it is all unlocked, unfrozen and working as if nothing had happened.
I might treat it to a good clean for being a good RR. First time FFRR owner
Post #655811 6th Feb 2023 11:49am
Gremlin500
Hi Arch:
Amazing how LR managed to fine-tune the reliability of the App to closely match that of the car Rolling with laughter
Hmmm, I wonder if the App requires a fully-charged battery in order to perform correctly?
Could be just like the car…………. Whistle Mr. Green “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #655843 6th Feb 2023 7:15pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I've had / am having the same issue.
Bought the subscritiption a week after purchasing the car and it worked fine for a month - Then it just stopped.
I get a meesage on the app that "The onbpard telematics system is currently in sleep mode to help preserve the battery. To refresh the data please start the vehicel"
That was 3 months ago and I have done plenty of long jouirneys so the battery would be fully charged (no other battery related faults appear anyway)
I've also cleared the fault codes and nothing - I even tried to remove the car from my account and the LR systems seems to have stuck at "The request to remove has started but not completed yet" (or similar) - I suspect the module is fubar now.
Planning to go to the garage for another warranty issue with my non deployable, deployable side step so will ask them to look at it then. Ash
2016 SDV8 AB
Post #655857 6th Feb 2023 8:34pm
M11buc
United Kingdom 2019 Range Rover Autobiography SDV8 Santorini Black
Hi comports, it could possibly be faulty telematics control unit. There are a few thing you can do to reset it and see if will reboot. Locate unit ( normally behind n/s c pillar trim) unplug the unit and remove the internal battery. Give it ten minutes and refit it, clear all dtc,s. This might then boot up. Also uninstall and reinstall the app and follow the sos button reset. If after that it still refuses to work May need new unit ( which were and are still possibly on back order)
Post #655883 7th Feb 2023 2:46am
comports
Thanks M11
The only thing behind the NS C Pillar is this....
I did remove it and openit up but there was no internal battery - I suspect this is not the telematics module. Big Cry
At least I know how to remove the C pillars now though Laughing
Any other ideas where I might it..??
Thanks Ash
2016 SDV8 AB
Post #655911 7th Feb 2023 12:29pm
the location is in the WM,
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #655912 7th Feb 2023 12:39pm
comports
Thank you Stan Bow down
Now to find a guide on removing the lower dash tray (Drivers side) Laughing Ash
2016 SDV8 AB
Post #655916 7th Feb 2023 12:59pm
M11buc
Hi, not sure on your reg number to check but found this if helps. ( or not as the case maybe )
Post #655927 7th Feb 2023 3:02pm
Page 1 of 3 123>
