Home > Technical (L322) > 2010 4.4 TDV8 - P2264-00 (2F) Water in fuel sensor circuit |
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 154 |
yep - still no issue from me....well, not on the water sensor front anyway! 2010 L322 Autobiography Black Edition
14th May 2023 4:29pm |
Grundey2 Member Since: 03 Jan 2023 Location: Lincolnshire Posts: 31 |
I have the same issue as the OP
12th Jul 2023 7:55pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1364 |
There's a known fault with the water-in-fuel sensor. It is also easily damaged if plugged into the wrong bit on the bottom of the fuel filter.
12th Jul 2023 11:37pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 763 |
Gary
13th Jul 2023 8:16am |
LR022663 2015 Range Rover Autobiography 4.4 SDV8 |
13th Jul 2023 8:26am |
Mfcetin Member Since: 26 Jun 2023 Location: Nuremberg Posts: 46 |
Hi Gents and Ladies (if there are any)
20th Sep 2023 9:44am |
It's quite common for the contact inside the rubber plug to break over time and cause the water in fuel sensor fault code.
20th Sep 2023 9:51am |
Thank you for the tip, I asked maltings if that loom will ever be available again but will also order a 3.6 tdv8 assembly. You are sure that the loom will fit my 4.4 Tdv8? 2011 Vogue SE 4.4 TDV8 |
20th Sep 2023 10:23am |
Yes, it fits.
20th Sep 2023 11:09am |
2 months ago I replaced the cable loom with a second hand one from a 3.6 tdv8. The water in fuel error and yellow restricted performance warnings were gone for about 3 weeks. I got the water water in fuel error again once I started to work on the egr temp sensor. The fault came back when I unplugged the broken temp sensor. I could not undo the sensor so I had a mechanic removed it. I was hoping that the water in fuel and restricted performance will not come back as all connections are done now but unfortunately it was not the case. Now i have no p040 fault but water in fuel fault comes up now and then which brings the restricted performance warning on the dash. That is really annoying.
5th Nov 2023 11:00am |
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 69 |
I purchased the below and it fixed my issue:
8th Dec 2023 11:15pm |
This has been out of stock since a long time. Where did you buy this from? 2011 Vogue SE 4.4 TDV8 |
9th Dec 2023 6:02am |
I managed to get one from that advert. have you messaged them? LR072685S is their reference number. LR072685 is the number for the whole housing if you can't get the sensor on its own (pricey) |
9th Dec 2023 8:58am |
I contacted Maltings several times, they told me there was one last item left and I could buy it but they never got back to me unfortunately.
27th Dec 2023 2:20pm |
