Home > Technical (L405) > rear end sliding |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
i've searched the forum and cant find anything similar to my problem..
30th Jul 2023 12:52pm |
did the first oil change solve your problem Nick? ... - .- -.
30th Jul 2023 3:30pm |
nickt68 Member Since: 05 Nov 2010 Location: Herts Posts: 97 |
Yes, big improvement straight away Stan but it has gradually come back, albeit not as bad, over the last few thousand miles. I'm hopeful that the next change should fix it for good! It's just an oil change this time and not the software update too |
30th Jul 2023 3:39pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
My L322 did that Stan and it turned out to be a rear hub bush. According to my Indy, it’s hard to find with a pry bar because they check it with all the weight of the car loaded on it, making it seem ok. Got - 2017 SDV8 Autobiography in Loire Blue
30th Jul 2023 4:37pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7925 |
Could it be this Stan...
30th Jul 2023 5:08pm |
thats interesting Pete and although it refers to a judder rather than the sliding rear , it could solve my problem.
30th Jul 2023 5:49pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1133 |
Hi Stan
30th Jul 2023 6:56pm |
i dont know Alex...how do i determine this?
30th Jul 2023 9:12pm |
Lots of ways to find out but you can do it this way from your seat...!!!
30th Jul 2023 10:01pm |
The Dealership had to get confirmation from technical at JLR to change the diff which the warranty company then approved,
31st Jul 2023 8:42am |
didnt realise this info was on the build sheet Pete..
31st Jul 2023 9:32am |
When you go to the screen 4x4 information it will show a padlock (or not).
31st Jul 2023 12:35pm |
Looks like you don't have a locking rear diff. You are back to the double flush and software update on the transfer box... Pete
31st Jul 2023 1:17pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Stan, when you checked the car on the ramp, did you only check the car with the suspension on full droop? |
1st Aug 2023 12:15am |
