Home > Maintenance & Mods (L322) > Front Hub Strut Bolts - knock out or screw out? |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 374 |
Hi All,
10th Aug 2023 11:01am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
Its not a thread on them, just concentric rings, there tight in there and one proved impossible for me to remove without putting things back together and taking it to a garage, who also had a hell of a job removing it....
10th Aug 2023 11:25am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7914 |
After the nut is off it is often easier to use a rattle gun on it and spin it to free the rusting, just trying to drift it out is usually the hard way....!! Pete
10th Aug 2023 11:54am |
Thanks both - I've got the nuts off and managed to turn the top bolt (with a scaffold pole!) 1/4inch but that's it. Think I'll get some heat/Plus Gas on them and work on them slowly.
10th Aug 2023 12:20pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1142 |
If using heat just be careful that you do not put too much heat into the strut. Good luck |
10th Aug 2023 5:05pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 588 |
just done both front struts on mine took 2 hours to get drivers side bottom bolt out |
10th Aug 2023 9:28pm |
What method did you use please? Gavin 2005 Range Rover Vogue SE 4.2 Supercharged V8 1998 Defender 50th Anniversary - GB168 - preparing for sale Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg |
11th Aug 2023 7:51am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Plenty of release oil, leave the nuts on the bolts but unscrewed about 5mm then a large hammer on the nuts. Intermittently put a socket on the bolt head and try turning it, then back to the hammer.
11th Aug 2023 8:26am |
Thanks nicedayforit
11th Aug 2023 8:47am |
If you are going to do all the work on the Fatty yourself it does make a lot of sense to buy an electric rattle gun, what takes minutes with one can take hours with conventional tools... The first time you use it, it has paid for itself.... Pete
11th Aug 2023 9:22am |
Can you recommend one from personal use Haylands ?
11th Aug 2023 9:57am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Sorry Pete I have to disagree, when it comes to these bolts being “properly seized” I literally use a 10ft truck 1” bar! Can take a good two hours a side! I have a class leading rattle gun and that would have no chance in moving “properly seized “ bolts sir… |
11th Aug 2023 10:30am |
That's interesting Craig, I must say the last few I have done have come out with a rattle gun but I guess they weren't as tight as some you see, I guess I've been lucky...
11th Aug 2023 2:43pm |
It’s a bit of a lottery Pete… It’s not the nut and bolt that seizes, it’s the length of the bolt shaft that rusts, then seizes the 3 or so inches it spans the hub casting and air strut… 3 out of 10 will be easy. 4 out of 10 will be seized and the last 3 will be They are the ones you need the big kit for! |
11th Aug 2023 3:12pm |
