Home > Maintenance & Mods (L322) > Front Hub Strut Bolts - knock out or screw out?
Superspoons
Hi All,
Looking for a bit of advice please ...
Anyone know if the Bolts on the Front Hub have to be undone or can they, as I've seen on a YouTube video, be knocked out with a drift once the nut is off?
The reason I ask is the new bolts I been sent have a thread on the part of the bolt that sits within the hub - its also slightly wider in diameter than the 'nut end'...
...and yes....both mine are stuck solid.. I'm trying to fix a split CV boot.
This one -
Cheers Gavin
1998 Defender 50th Anniversary - GB168 - preparing for sale
Post #670871 10th Aug 2023 11:01am
dingg1
Its not a thread on them, just concentric rings, there tight in there and one proved impossible for me to remove without putting things back together and taking it to a garage, who also had a hell of a job removing it....
Good luck 🤞 you can manage it
Post #670873 10th Aug 2023 11:25am
After the nut is off it is often easier to use a rattle gun on it and spin it to free the rusting, just trying to drift it out is usually the hard way....!! Pete
Post #670875 10th Aug 2023 11:54am
Superspoons
Thanks both - I've got the nuts off and managed to turn the top bolt (with a scaffold pole!) 1/4inch but that's it. Think I'll get some heat/Plus Gas on them and work on them slowly.
...I thought the bottom ball joints I replaced a few weeks back were a pain... and then I have the drive shaft to get out but I have a 10t puller for that if an air chisel doesn't free of the rust within... Gavin
Post #670879 10th Aug 2023 12:20pm
Merchy
If using heat just be careful that you do not put too much heat into the strut. Good luck Thumbs Up
Post #670899 10th Aug 2023 5:05pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
just done both front struts on mine took 2 hours to get drivers side bottom bolt out Rolling with laughter Rolling with laughter
Post #670927 10th Aug 2023 9:28pm
Start with a 10ft bar and work downwards until they come out! PUT SOME COPPER GREASE ON THE BOLTS WHEN REINSTALLING Thumbs Up
Post #670943 11th Aug 2023 1:57am
Superspoons
What method did you use please? Gavin
Post #670948 11th Aug 2023 7:51am
Plenty of release oil, leave the nuts on the bolts but unscrewed about 5mm then a large hammer on the nuts. Intermittently put a socket on the bolt head and try turning it, then back to the hammer.
Mine came out this way although l had to renew one of the bolts.
I treated getting the 4 bolts out as an exercise on its own before removing the struts. Took out one bolt at a time cleaned and copper greased it and then put it back.
As a result when l came to change the struts the bolts came out easily, the first strut change took an hour and a half, the second one 40 minutes.
Unless you are very lucky l wouldn’t try to do the whole job in one go. Thumbs Up
Post #670953 11th Aug 2023 8:26am
Superspoons
Thanks nicedayforit
I'll treat them just as I did for my suspension ball joints - plenty of preparation with the wire brush, Plus Gas and sockets/bars/prayers Thumbs Up Gavin
Post #670954 11th Aug 2023 8:47am
If you are going to do all the work on the Fatty yourself it does make a lot of sense to buy an electric rattle gun, what takes minutes with one can take hours with conventional tools... The first time you use it, it has paid for itself.... Thumbs Up Pete
Post #670955 11th Aug 2023 9:22am
Superspoons
Can you recommend one from personal use Haylands ?
I'm hoping to get access to a 1000Nm cordless one .... if that doesn't do the job then .....
cheers Gavin
Post #670959 11th Aug 2023 9:57am
Sorry Pete I have to disagree, when it comes to these bolts being “properly seized” I literally use a 10ft truck 1” bar! Can take a good two hours a side! I have a class leading rattle gun and that would have no chance in moving “properly seized “ bolts sir… Thumbs Up
Post #670964 11th Aug 2023 10:30am
That's interesting Craig, I must say the last few I have done have come out with a rattle gun but I guess they weren't as tight as some you see, I guess I've been lucky...
I know I used a 3/4" drive HGV rattle gun on a rear upper bush bolt on fatty off roader and that snapped the 20-25 mm bolt...
Cancel my last everyone, get a 10ft bar but please make sure the fatty is properly supported, with a lever that long you could easily knock it off the jack...!!
Superspoons, my home one is a 20v Dewalt which does work well, when I work on fatties I usually do it at my mates on a twin post ramp, with his air guns, it's just so much easier... Thumbs Up Pete
Post #670980 11th Aug 2023 2:43pm
It’s a bit of a lottery Pete… It’s not the nut and bolt that seizes, it’s the length of the bolt shaft that rusts, then seizes the 3 or so inches it spans the hub casting and air strut… 3 out of 10 will be easy. 4 out of 10 will be seized and the last 3 will be Censored Censored Censored They are the ones you need the big kit for! Thumbs Up
Post #670983 11th Aug 2023 3:12pm
