Home > Maintenance & Mods (L405) > 2017 L405 ACE Drop Links/ARB Bushes |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 593 |
The links themselves are common between cars with/without ACE.
24th Aug 2023 10:42am |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 208 |
The bushes for the ACE equipped vehicles are different - MY18-on are also slightly different again.
26th Aug 2023 9:18am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1699 |
Been there, done that. Not fun
26th Aug 2023 11:45am |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 161 |
That's great thanks chaps!
29th Aug 2023 7:46am |
All fitted - knocking gone and a huge improvement on the drive! Thanks all |
17th Sep 2023 9:34pm |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 221 |
Did you do the rear?
18th Sep 2023 3:22pm |
Used aftermarket, these are fairly common on RR’s and basic tech, so I didn’t see the need for the added OEM expense.
18th Sep 2023 3:34pm |
Thank you. I replaced my fronts previously with Mevotech. The “may” be part of the knock return. I will try Delphi next front and rear. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
18th Sep 2023 3:36pm |
Think Delphi are a decent brand for this application. If you can get Febi Bilstein in CA then so far so good! |
18th Sep 2023 5:34pm |
I had trouble getting the previous ones to torque. I had to use vice grips on the backside collar to reach 185nM. Maybe the Delphi will be better and won’t spin all the way to torque. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
19th Sep 2023 2:05am |
