Home > Technical (L322) > air suspension
Page 1 of 3 123>
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
air suspension
I have a problem with the air suspension.
Three days ago, while driving, I realised the left front suspension was down.
By the time I had got home it was normal and stayed normal for the next two days.
Now its down again, there is no air atall in the air bag.
If the air bag had a air leek, I would have thought the air compressor would be running, trying to fill it, so I am thinking there is a fault in the leveling system.
What are your thoughts
thanks RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #677605 9th Nov 2023 2:45pm
knares
ok RR 2005 4.4 petrol
Post #677639 10th Nov 2023 2:47am
knares
the gap tool says
0x32 CAN BUS fault
0x64 Articulation validity fault RR 2005 4.4 petrol
Post #677650 10th Nov 2023 10:43am
stick it in off road and test the air bags for leaks....
i think its a process of elimination and the above is the first thing i would do.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #677652 10th Nov 2023 11:09am
knares
thanks for your reply
i had removed the front wheels and the height sensors, so i put it all back and cleared the fauls and up it went to off road height
couldn't hear any leaks, put it to access, then to normal, all fine so far
no faults RR 2005 4.4 petrol
Post #677715 11th Nov 2023 12:52pm
knares
its flat this morning so i assume the bag is leaking
i thought the compressor would have blown it up as it was going down
obviously not RR 2005 4.4 petrol
Post #677753 12th Nov 2023 7:04am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Sounds like an air bag to me I'm afraid. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #677755 12th Nov 2023 8:42am
knares
yes, i think you are right, it dose look in good condition, i will see when i get it out.
i will have to try and test it some how if i still cant see any damage RR 2005 4.4 petrol
Post #677772 12th Nov 2023 12:41pm
Range Rover L322
Airbags often get leaks at this time of year as the weather gets cooler.
Front left is the usual culprit - it takes more bumps being on the side of the road.
It can be intermittent as the hole can be in a place where it is folded against itself and therefore will not leak.
Good luck. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH (Ex LR Chief Technician)
Post #677888 13th Nov 2023 10:24pm
knares
thanks for your post RR 2005 4.4 petrol
Post #677901 14th Nov 2023 2:03am
knares
I left the car parked up four 4 days and the air bag was still up.
I took it out, about 5km, next day the bag was still up.
Drove about 30km and it went down.
It seams all over the place RR 2005 4.4 petrol
Post #678122 17th Nov 2023 3:48am
garyRR
Faulty/sticking valve block inside the wheel arch? 2015 Range Rover Autobiography 4.4 SDV8
Post #678195 18th Nov 2023 12:45am
knares
garyRR
could you give me more info on that please
where is it exactly, how do i get to it, what dose it look like
i have no idea
Post #678198 18th Nov 2023 2:26am
will308f
United Kingdom 2008 Range Rover Vogue TDV8 Orkney Grey
the valve block can be found behind the wheel liner on the front right wheel looks like this Thumbs Up 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather
Post #678520 22nd Nov 2023 6:31pm
knares
Post #678541 23rd Nov 2023 12:53am
Page 1 of 3 123>
