Home > Technical (L322) > air suspension |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 701 |
ok RR 2005 4.4 petrol
10th Nov 2023 2:47am |
the gap tool says
10th Nov 2023 10:43am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34937 |
stick it in off road and test the air bags for leaks....
10th Nov 2023 11:09am |
thanks for your reply
11th Nov 2023 12:52pm |
its flat this morning so i assume the bag is leaking
12th Nov 2023 7:04am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 521 |
Sounds like an air bag to me I'm afraid. Drives:
12th Nov 2023 8:42am |
yes, i think you are right, it dose look in good condition, i will see when i get it out.
12th Nov 2023 12:41pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 307 |
Airbags often get leaks at this time of year as the weather gets cooler.
13th Nov 2023 10:24pm |
thanks for your post RR 2005 4.4 petrol
14th Nov 2023 2:03am |
I left the car parked up four 4 days and the air bag was still up.
17th Nov 2023 3:48am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1364 |
Faulty/sticking valve block inside the wheel arch? 2015 Range Rover Autobiography 4.4 SDV8 |
18th Nov 2023 12:45am |
garyRR
18th Nov 2023 2:26am |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 247 |
the valve block can be found behind the wheel liner on the front right wheel looks like this 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
22nd Nov 2023 6:31pm |
thanks RR 2005 4.4 petrol
23rd Nov 2023 12:53am |
