Home > In Car Electronics (L322) > Dash Cams for the L322 |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
I've used Thinkware dashcams for years - now on the F880Pro. Works well, good image quality and night vision. the rear camera comes with a cable that is plenty long enough for Range Rovers and can be pulled through the tailgate grommets reasonably easily. The front camera is unobtrusive and doesn't have one of those pointless screens on it.
12th Nov 2023 10:11am |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 383 |
I have a lesser model Thinkware that I don't use the park function and the pictures are great First time FFRR owner |
12th Nov 2023 12:45pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1356 |
Any old dash cam will be useful to prove non-fault. They tuck quite nicely behind the rear view mirror, out of sight for the driver. 2015 Range Rover Autobiography 4.4 SDV8 |
16th Nov 2023 3:21pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34931 |
agree with Gary..
16th Nov 2023 3:59pm |
I forgot to mention, you may find this useful. I wrote a how-to for both mid and late cars:
16th Nov 2023 6:55pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 762 |
Will go with Thinkware
18th Nov 2023 10:43am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
I have used knock off go-pros in all my cars for years. They are extremely cheap, come with lots of fitting options have good resolution and wide angle lenses. Just ensure you set up the cycle record and for it to turn on and of with external power. I fit a cheap usb 12v inverter up in the roof consol area and run the usb cable to the top of the windscreen behind the rear view mirror where the go pro is fitted. 2007 TDV8 VSE
23rd Nov 2023 6:49am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4240 |
I use the Garmin Mini as its small and discrete and no screen. All set up via an app etc.
23rd Nov 2023 8:29am |
You can clip it to the back of the headlining. If you gently lever it down, you can feed a cable through and down the rear pillar (these also pull off quite easily) into the rear fuse box and hey presto. 2015 Range Rover Autobiography 4.4 SDV8 |
23rd Nov 2023 9:00am |
It's the clip/mounting that I'm head scratching over for the Garmin Mini
23rd Nov 2023 12:09pm |
Stick it to the window and mount it in the upper tailgate?
23rd Nov 2023 7:38pm |
Kiss My Carbon Footprint Member Since: 19 Dec 2020 Location: Milton Keynes Posts: 115 |
Removing the L322 tailgate upper trim panel requires great care.
24th Nov 2023 12:52am |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
I got a couple of these almost 10 years ago, and both are still working well, great image quality, and loads of features, G-sensor, etc.
24th Nov 2023 10:54am |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 274 |
I’ve got one of these and switch it into whichever car I’m using, you can get moody fittings on the bay - it’s a 10mm ball if I recall. I was thinking of getting a rear one and also pondering where to mount it, but it’ll probably go in the top of the screen so I can switch it onto the defender easily. |
3rd Dec 2023 9:57pm |
