Home > Maintenance & Mods (L322) > DPF Am I going paranoid? |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2786 |
Soot building up way, way too fast. Probably a good idea to get the sensor replaced ( or check the wiring) to rule this out. Is your mpg normal ? 2012 TDV8 Vogue (L322) |
13th Dec 2023 3:20pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3692 |
Was the smoke test high enough pressure ?
13th Dec 2023 4:21pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
13th Dec 2023 4:51pm |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 120 |
That's what I thought so I kept upping the pressure until it eventually blew the bung out!! 2011 4.4 TDV8 Vogue SE 1993 Discovery 1 3.5 V8i |
13th Dec 2023 5:45pm |
I believe the soot content is calculated from the differential between the two pressure sensors and as the soot content came down gradually to 0.3 grams during the regen I assumed that they must be working. The O2 sensor is a bu**er to get out. I would like to test the wiring but can't see where it connects to the loom. Any tips? 2011 4.4 TDV8 Vogue SE 1993 Discovery 1 3.5 V8i Last edited by TomCobbly on 15th Dec 2023 10:28am. Edited 1 time in total |
13th Dec 2023 5:51pm |
If you go to the WIKI section there are lots of technical docs inc wiring diagrams and workshop manuals. 2012 TDV8 Vogue (L322) |
13th Dec 2023 6:14pm |
I've got the wiring diagram ok but I need the physical locations of the two inline connectors C1559 and C2759D and I can't find them. Someone on the forum has the part number as LR001370 but that appears to only have 5 wires and the wiring diagram has 6. Can anyone confirm the HO2S sensor part number for me please? 2011 4.4 TDV8 Vogue SE 1993 Discovery 1 3.5 V8i Last edited by TomCobbly on 13th Dec 2023 7:51pm. Edited 1 time in total |
13th Dec 2023 7:34pm |
13th Dec 2023 7:40pm |
The sensor wire seems to disappear over the rear of the engine and the connector isn't visible. Anyone had any experience of changing this sensor? Someone on the forum has the part number as LR001370 but that appears to only have 5 wires and the wiring diagram has 6. Can anyone confirm the HO2S sensor part number for me please and if it only has 5 wires? 2011 4.4 TDV8 Vogue SE 1993 Discovery 1 3.5 V8i |
15th Dec 2023 10:25am |
