Home > Technical (L322) > Side step problem |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
aluminium is a fairly soft metal so you could try drilling it out.. ... - .- -.
4th Jan 2024 2:39pm |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 154 |
Try a local blacksmith or metal working shop, they usually are very useful in extracting and manufacturing parts, certainly things like pins etc. |
4th Jan 2024 5:19pm |
Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212 |
Yes, I was thinking of drilling it out. But I don't seem to be able to manage it without damaging the sliding bushing. Is there any way of getting a replacement for that? |
5th Jan 2024 10:36am |
the trick to drilling is to drill a smaller diameter which leaves a thin outer sleeve of aluminium ..you then collapse this sleeve inwards ... ... - .- -.
5th Jan 2024 11:31am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Or chuck the whole side step assembly in the skip 😂 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
5th Jan 2024 1:27pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 253 |
Hi @Squirrel; Thanks for posting this; I am planning a refurb of my side steps soon as the drivers side, which is obviously used the most, is developing a jerky action. I’m interested to know how your refurb goes so please keep us all updated.
7th Jan 2024 7:40am |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 157 |
@ Squirrel
8th Jan 2024 10:43am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
I replaced a step motor and it was a hell of a job! It's an interference fit and I ended up cutting the bracket off around it (very carefully) with an angle grinder! It also has a flat on it, which makes it even trickier.
8th Jan 2024 10:55am |
@ Stan
8th Jan 2024 4:47pm |
If anyone is interested - I've just found side step brackets for the L322 on AliExpress. From China. I doubt they're any good, but I've ordered one anyway, just to see what happens. I'll keep you posted. |
8th Jan 2024 5:32pm |
Hope this helps! |
9th Jan 2024 1:26pm |
Are the late L322 motors and the L405 really that different. They look very similar. I can find loads of L405 copies on euro sites but all the ones for the L322 (LR004807) are all genuine and stupid money. I have found a pair on uk ebay which is £200 plus shipping plus £70 import charges so roughly €400, which is a bit high
9th Jan 2024 2:35pm |
I don't know about the motors, but the brackets look quite different. I'd put money on LR altering the motors slightly between the two variants so that one doesn't fit the other. |
10th Jan 2024 11:36am |
If anyone's interested, I resolved the problem by buying a part off AliExpress - £76. It wasn't perfect and required a bit of fiddling with the motor to get everything to fit, but I now have two fully functioning side steps. |
26th Jan 2024 5:57pm |
