Home > Maintenance & Mods (L322) > EGR blanking, 3.6 TDV8 (2009) |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 253 |
Lot’s of mixed opinions on here wrt EGR blanking, especially for the TDV8 3.6. I recently had a lengthy discussion with my Indy on this topic and was advised, for the 4.4, that the EGR was best left alone with the exception of periodic cleaning of the pipes & sensors.
19th Feb 2024 6:23pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2706 |
Renewal is a lot of £££. All moden engines have IAT sensors so the ECU can compensate for normal changes in intake temp and measure fuel accuratley either from EGR function or driving on a hot or cold day. Increasing fuel pressure to compensate for a lack ofan EGR is simply not true. Increasing fuel pressure to increase power is a tuning strategy nothing to do with EGR's. EGR's can start to cause probelms as they wear, age or get carbon fouled as they start to slow down in their ability to shut off the egr flow when you come on power leading to hesitation or simply never close properly leading to all sorts of drivability issues. At worst and as it seems to be the case on the 3.6 engine they actual fall apart and throw parts into the turbo and engine. The 4.4 is a later engine with a more sophisticated and reliable EGR setup which is also integrated into the DPF soot control system so best left alone as you indy rightly points out. 2012 TDV8 Vogue (L322) |
19th Feb 2024 6:57pm |
rryan Member Since: 17 Feb 2024 Location: New Forest Posts: 13 |
Thanks for the inputs, some really interesting points and it's good to hear different views!
20th Feb 2024 10:39pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4242 |
The 3.6 is a much easier decision when it comes to EGR blanking. Overwhelming opinion is to blank them both of them. Do it physically and electronically. Former is easy via a kit. Latter requires a plug in which I would recommend you buy a gap IID Bluetooth and then get BAS to map it out over the internet. The IID is invaluable for code clearing and reading plus CCF updates etc. I wouldn’t drive an L322 without one in the glovebox for peace of mind.
20th Feb 2024 10:48pm |
