Home > Maintenance & Mods (L322) > External trim color |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Hi Guys
15th Jun 2011 7:49pm |
Cheers. Will do. Not sure if its a common fault or I've just been unlucky, but both mirror bases look bloody awful. |
15th Jun 2011 10:00pm |
All finished, well one side anyway. Peice of job. Used the powerful uk video on YouTube on how to remove the mirror. Once off removed the finishing cover from under the mirror and masked off the mirror. Unfortunatly I couldn't fully separate the base from the mirror but it helped when masking and sanding. I used a screwdriver to get the corroded powder coat off then a Stanley knife to help get the powder coat off past where the corrosion ended. Once this was done I used some sandpaper to remove the corrosion from the aluminium to get it back to bright alloy. The sandpaper also helped to blend the powdercoat into the aluminium. Once this was done gave it 2 coats of primer allowing plenty of time to dry between coats. Then 3 coats of satin black. Leave to dry then refit. Easy peazy. While doing the mirror I resprayed the bonet vent as per joe90's post. Will upload a few photos later when I get time. |
16th Jun 2011 3:57pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
looking forward to the pics ROB.. |
16th Jun 2011 4:03pm |
Here are a few pics.
16th Jun 2011 6:53pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Top Job what colour did you use for bonnet vent? |
16th Jun 2011 6:58pm |
Its Rover stone silver. Used the same as Joe90. |
16th Jun 2011 7:04pm |
