Home > Technical (L322) > L322 Rear sub frame bush replacement info
Page 3 of 3 <123
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
From what I've read on various forums there's a suspicion in some quarters that Land Rover's OE rear subframe supplier may have made some of the subframes slightly oversize & Land Rover being Land Rover decided to use them anyway due to production pressures, but using a large rivet through the side to ensure the bushes stayed in place.
Who knows what's actually true - other than some cars have rivets and many don't ! Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #690700 15th Apr 2024 10:23pm
vektory
Austria 2012 Range Rover Vogue TDV8 Sumatra Black
Just for clarity - this is what the situation did look like.
I have not installed rivets afterwards for the new bushes. TDV8 4.4 MY2012 Vogue Trim
Post #690709 16th Apr 2024 9:04am
mgrover
What am not understanding is how are they falling down?
Like why isn't the bolt/backing plate holding them into place? Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #690723 16th Apr 2024 11:42am
vektory
I think that the rivets are protecting the bushes against rotation, as they cannot fall down. TDV8 4.4 MY2012 Vogue Trim
Post #690724 16th Apr 2024 12:09pm
mgrover
hmm okays, i guess ill get the rivets, the subframe will be dropped slightly anyway as I need to reinstall the control arms. Its actually a sport Sad
Post #690725 16th Apr 2024 12:16pm
will308f
United Kingdom 2008 Range Rover Vogue TDV8 Orkney Grey
to those who have replaced the bushes already .............did you feel any difference before and after ?
will 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather
Post #690736 16th Apr 2024 2:58pm
mgrover
i mean ive replaced them.
i felt a great sense of relief and accomplishment.
...oh you mean how does the car feel to drive? no idea all the other suspension bits are being rebuilt Laughing
am replacing more or less all the rear bushings meaning i wont be able to tell whose fault for what. Its actually a sport Sad
Post #690738 16th Apr 2024 3:03pm
will308f
Rolling with laughter Rolling with laughter Rolling with laughter ...was thinking of doing mine that was all that have come up on mot but rubber is rubber and it wears 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather
Post #690740 16th Apr 2024 3:14pm
vektory
will
I did replace them as they told me on MOT that they need replacement. However once I had them out of the frame I could not really see any proper damage. Besides the f* rivets. I think that they have probably misjudged the anti-corrosion coating that was also painted on the bushes a little bit.
That said, I did not really notice a big difference before and after...despite the great sense of accomplishment just like mgrover said above Very Happy TDV8 4.4 MY2012 Vogue Trim
Post #690742 16th Apr 2024 3:23pm
mgrover
tbh out of all the jobs ive done this is the easiest.
get the tool, get a right rachet spanner and get a pole that can go around it. Its actually a sport Sad
Post #690743 16th Apr 2024 3:23pm
vektory
a little side question for @mgrover: do you have any hints on how to break the ball joint in the front?
I tried my best with a 4 lbs hammer and specific fork but this thing did just not move at all. Only the fork got stuck....
Post #690744 16th Apr 2024 3:27pm
will308f
tool is on my list of things to get ....working on replacing front suspension at the mo,but when finished will move on to the rear and do the same she should feel like new when I'm done Thumbs Up 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather
Post #690745 16th Apr 2024 3:30pm
mgrover
theres a video I saw somewhere that just used a balljoint breaker.
after i finish my rear at some point ill redo the entirety of the front as well Its actually a sport Sad
Post #690750 16th Apr 2024 4:21pm
vektory
A regular balljoint breaker does not fit in between these two arms. However if you start with the lower control arm first, then there is also enough space for the tie rod and its ball joint. Changing the ball joint alone seems to be problematic.
I might need to release both ball joints :/ TDV8 4.4 MY2012 Vogue Trim
Post #690752 16th Apr 2024 5:10pm
Page 3 of 3 <123
