Home > Maintenance & Mods (L322) > Refurbed door plastics |
f4rrs Member Since: 22 Jun 2011 Location: St Albans Posts: 20 |
NICE JOB |
7th Jul 2011 5:23pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34924 |
very nice work..leave it as it is as the range looks ok with a few different colours.
7th Jul 2011 5:52pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Nice job, FYI Supercharged RR's had piano black door handle surrounds rather than foundry finish, so my vote is to keep it black
7th Jul 2011 6:19pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
I have a similar problem with badly scratched panels and was thinking of spraying them. How easy was it to sand the rubbery finish on the switch panels, can it be painted over or did you have to get it all off? No longer FF owner but still interested. Present car Jaguar XE
7th Jul 2011 6:25pm |
AndrewT Member Since: 20 May 2011 Location: Auckland Posts: 97 |
Thanks for the positive reviews.
7th Jul 2011 6:34pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
i painted all mine gloss black and as said earlier so long as you give them a good sand down and use a etching primer they do come out well ....on mine i did lots of coats then when it dried i wet and dried it so that i could get a nice gloss finish.........with regards to the window switch surrounds mine are pealing to so im just gonna take all the rubber coating off and have them just black plastic
7th Jul 2011 7:03pm |
Not sure whether the plastics stayed the same over the years but the switch surround plastic looks really cheap and nasty under the rubber. It's got a shiny but textured finish and wouldn't look out of place in an 80's Vauxhall. Have a look but you might want to prime and flatten before using the same paint as your handle trims to get a finish that's as good as what you've already done. Nice tip for the steering wheel spokes as I was wondering how I was going to tackle them without taking the whole thing apart. |
7th Jul 2011 7:26pm |
andrew i fear you may be right about the switch surrounds so maybe once ive got the rubber off ill just paint them like the rest with regards to the polish trick i found the cheaper the polish the better it worked....dont get me wrong it still takes a bit off elbow grease and does take some time to start working but it does work "RANGEISM WILL NOT BE TOLERATED"
7th Jul 2011 7:56pm |
grant Member Since: 06 Jun 2011 Location: Dunmow Posts: 24 |
Really looks great Andrew - I prefer that to the Foundry finish. I'll pop in to Halfords on the way home; busy weekend ahead. Tow bar electrics and now spraying. |
8th Jul 2011 1:45pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
can we see some pics of your gloss black parts i want to change mine to gloss black |
9th Jul 2011 7:14pm |
there on my range rover thread
9th Jul 2011 8:14pm |
9th Jul 2011 8:20pm |
thanks for that! |
9th Jul 2011 10:09pm |
Very nice. Same colour as mine. I need to have a go at that when I get some free time. So much to do and so little time No longer FF owner but still interested. Present car Jaguar XE
9th Jul 2011 10:32pm |
