Home > Maintenance & Mods (L322) > Dash lights very dim and LED lights dim in roof |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
Hello all,
30th Aug 2011 9:29am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34917 |
welcome simes..
30th Aug 2011 9:38am |
How bizarre. The lights in the binnacle are LED's and are not "user replaceable" however some have upgraded them to white LED's so it must be possible...
30th Aug 2011 9:45am |
I've had a look at them and they look original - and the book mentions that they are supposed to be there! Might be worth taking them out I suppose to see what happens... |
There are LED's in the roof (front & rear) - this gives the "waterfall lighting" Next time its dark, put your hand up there and you will see the light. They are very directional so they don't distract the driver... One wouldnt usually even notice them. They are linked with the LED's in the door handles and the door pockets I believe. |
30th Aug 2011 9:46am |
Thanks for this Dan. The pixels are all good - that lights up and works perfectly! It's just the lighting - also none of the switches in the centre console light up - I guess they are supposed to, or are they lit by the light from the LEDs in the roof light - when they work too... I was thinking LCM - I guess they are expensive? |
30th Aug 2011 9:48am |
They don't work either... No light in the pockets or door handles. |
30th Aug 2011 9:50am |
i stand corrected re the leds , looked like normal baynet type bulbs to me..... |
30th Aug 2011 9:52am |
Apart from my normal pessimism regarding Land Rover faults, this is why I suspec the LCM - I reckon it's bulbs in the steering wheel - that are working perfectly - and everything else that is LED is not... |
30th Aug 2011 9:56am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
What and where are these "water fall" lights? I have the big light in the middle and 2 map lights? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
30th Aug 2011 10:54am |
Have you ever picked up a brochure for the car?
30th Aug 2011 11:01am |
Actually I haven't only the new My2011 which i no use to me. I never noticed those before. Knew there were holes but never noticed any lights in them. You live and learn. Going out to have a look at mine now to see if they work. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
30th Aug 2011 11:09am |
me they are there and they work! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
30th Aug 2011 11:34am |
i assumed OP was on about the light below red circles in dans pic.... |
30th Aug 2011 11:37am |
I have LEDs in my main bulbs through out the car and have no problems. I do however have a blown bulb/LED in the dash binnacle. where the milage is doesn't illuminate. Will try and get a pic later to see if its any help to Simms. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
30th Aug 2011 12:02pm |
