Home > Maintenance & Mods (L322) > Trim removal
Trim removal
Anybody have experience of removing the trim that surrounds the drivers window/mirror/access switches as I am fitting a replacement that I know pushes on but I want to know which end to pull up first to remove old?
Post #78666 1st Sep 2011 2:57pm
Just tried does not seem to want to pull off.... Confused
Post #78682 1st Sep 2011 4:10pm
Is it the switches panel?
Post #78687 1st Sep 2011 4:23pm
Yes!
Just seen that maybe its screwed on.....
Post #78688 1st Sep 2011 4:24pm
I take it you have removed the door card? You access them all from behind I think Discovery 4 HSE
Post #78691 1st Sep 2011 4:32pm
I think from memory the door car has to be removed to allow the switch panel to come off
Post #78692 1st Sep 2011 4:32pm
OK guys I thought it popped off but looking at the new trim I think its screwed in from behind the door card Thumbs Up
Post #78696 1st Sep 2011 4:43pm
Nothing in WIKI or search on Door Card Removal ?.
I am a dealer not a mechanic! Embarassed
Post #78697 1st Sep 2011 4:48pm
Always worth checking the Gearbox Linkage is not corroded/sticking! Rolling with laughter Rolling with laughter
Post #78699 1st Sep 2011 4:55pm
Now that I am expert at - will try and get back Thumbs Up
Post #78700 1st Sep 2011 4:56pm
any help?
Post #78701 1st Sep 2011 5:00pm
Perfect Stan but I WILL lose that first bolt Laughing
Post #78702 1st Sep 2011 5:02pm
Again from memory remove the two screws at the end of the pocket and the screw from the interior door handle. Using a large flay bladed screwdriver gently prize the bottom of the door card away from the door, it is held on with plastic poppers, once you have a couple of the poppers prized from the door use your hand to pull the card away. Once all poppers are loose lift the door card upwards to release it from the top
Post #78704 1st Sep 2011 5:03pm
get mini gaz to help you gary... Thumbs Up
Post #78705 1st Sep 2011 5:04pm
Oops forgot the 10mm bolt Big Cry
Post #78706 1st Sep 2011 5:04pm
