Home > Maintenance & Mods (L322) > Trim removal |
Anybody have experience of removing the trim that surrounds the drivers window/mirror/access switches as I am fitting a replacement that I know pushes on but I want to know which end to pull up first to remove old? |
1st Sep 2011 2:57pm |
Just tried does not seem to want to pull off.... |
1st Sep 2011 4:10pm |
Is it the switches panel? |
1st Sep 2011 4:23pm |
Yes!
1st Sep 2011 4:24pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6355 |
I take it you have removed the door card? You access them all from behind I think Discovery 4 HSE
1st Sep 2011 4:32pm |
I think from memory the door car has to be removed to allow the switch panel to come off |
OK guys I thought it popped off but looking at the new trim I think its screwed in from behind the door card |
1st Sep 2011 4:43pm |
Nothing in WIKI or search on Door Card Removal ?.
1st Sep 2011 4:48pm |
Now that I am expert at - will try and get back |
1st Sep 2011 4:56pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34943 |
any help? |
1st Sep 2011 5:00pm |
Perfect Stan but I WILL lose that first bolt |
1st Sep 2011 5:02pm |
Again from memory remove the two screws at the end of the pocket and the screw from the interior door handle. Using a large flay bladed screwdriver gently prize the bottom of the door card away from the door, it is held on with plastic poppers, once you have a couple of the poppers prized from the door use your hand to pull the card away. Once all poppers are loose lift the door card upwards to release it from the top |
1st Sep 2011 5:03pm |
get mini gaz to help you gary... |
1st Sep 2011 5:04pm |
Oops forgot the 10mm bolt |
