Home > Maintenance & Mods (L322) > Retro Fitting Nav system |
Stuart528 Member Since: 14 Nov 2009 Location: North West Posts: 25 |
Andy, did you get anywhere with this? I am refitting a standard monitor back into my car (2002 4.4 Vogue), as it had a big Kenwood screen fitted in the dash by the previous owner. Unfortunately, the wiring was all spliced into ISO plugs to go into the Kenwood, so I no longer have the two simple 12-pin plugs required to go into the standard RR unit.
17th Dec 2009 10:55pm |
I am relatively sure there is no retrofit loom. There are the original harnesses which aren't cheap and even more expensive to fit... The only other option - and possibly the most viable - is to modify a BMW harness to work.
18th Dec 2009 8:51am |
Stuart, the looms are all quite expensive. Generally bits of a harness aren't avail. either for exactly this reason. You're best bet is still from a breaker. If you can't find the plugs on the isles, let me know and I'll see if I can find a set at a reasonable cost in Germany. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
18th Dec 2009 8:55am |
Thanks a lot - but my problems were only just beginning - seems water ingress had wiped out some of the boxes in the boot, which must have been why previous owner replaced the head unit. I needed new DSP amp, new radio tuner, phone module was shot (but not bothered replacing).
3rd Jan 2010 10:22pm |
