Home > Maintenance & Mods (L322) > Rear washer...no washing cos there is no liquid! |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
thats because half of us have a f**ked rear wiper arm.
21st Jan 2011 11:22pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I hadn't even thought I had a problem. Thought my rear blade was shot but turns out the arms goosed. New arm to be ordered and then fix the water problem. |
22nd Jan 2011 4:23pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
Can the rear wiper arm be replaced by just removing the rear spoiler ? How does the water pipe connect up ?
19th Dec 2011 11:40pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6349 |
Yes it can it very easy.
20th Dec 2011 12:10am |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
The spoiler can be removed in minutes, but place an old towel on the roof to lay the spoiler on as the brake light cable is quite short.
20th Dec 2011 12:12am |
Thanks..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
20th Dec 2011 12:14am |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
LR will blast air through it to clear the crud out of the pipe then it will work again. I had this on my last FF, i could hear the pump trying to squirt the water but no water. A blast of compressed air and viola, worked like a charm.
20th Dec 2011 3:08pm |
I'm surprised they didn't charge you for the use of the Viola....
20th Dec 2011 4:55pm |
Haha oops, spell check corrected it without me seeing it |
20th Dec 2011 8:11pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3677 |
I have just had mine in pieces and got 1 jet working well, but the second jet won’t clear.
30th Nov 2019 3:34pm |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
Mine was a blocked nrv which can be cleaned carefully and replaced then cleaned and adjusted the jets all good now
30th Nov 2019 9:29pm |
https://www.fullfatrr.com/forum/topic50730.html
30th Nov 2019 9:31pm |
timse Member Since: 06 Dec 2019 Location: Farnborough Posts: 37 |
I had a blocked rear washer and took the one way valve (OWV) out as that was knackered. Put a new one on and no joy. I read all the threads about taking the rear washer apart etc but thought there must be an easier way.
23rd Jan 2020 5:32pm |
