Home > Maintenance & Mods (L322) > TD6 changing air and breather filter |
No more than a couple of hours, including tea breaks, should do it, if it is your first time at it and you have all the right tools and parts. .
22nd Feb 2012 6:46pm |
Sea Aitch Member Since: 17 Feb 2011 Location: Hertford Posts: 120 |
All pretty straight forward apart from the back bolt that fixes the air filter cover. It's a PITA to get out, and even more difficult to get back in. The way to make this so much easier is to remove the rubber trim and a couple of nuts so you can take out the pollen filter housing. It's not as extreme as it sounds (there's probably something on the forum if you search), and access to the breather filter and the rear of the air filter is so much easier. I found out the hard way |
22nd Feb 2012 6:49pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 719 |
Cheers guys
22nd Feb 2012 6:55pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6349 |
Does this help?
22nd Feb 2012 9:02pm |
bl00dy marvellous mr RRUK, many thanks!!! |
22nd Feb 2012 9:16pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
its all in the wiki mrblonde.. ... - .- -.
22nd Feb 2012 9:29pm |
Also here (for crankcase breather filter location)
23rd Feb 2012 1:10pm |
When you've changed the fuel filter before starting put the ignition on and wait approx 40 seconds until the tone changes on the fuel pump... That way you dont cane the starter motor whilst it builds fuel pressure to start...
23rd Feb 2012 2:09pm |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 |
I followed the info on wiki doing mine for the first time and i did eveything including oil change, fuel filter, air filter, crankacse breather (i changed the whole valve) and it took me a afternoon. The back nut as stated is not the easiet but i put some cloth on the bumper and front and climbed in!!!!
24th Feb 2012 12:50am |
