![]() | Home > Technical (L322) > Fuel Burning Heater on MY2007 SC |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Is this one of those things that was fitted but not activated? E.g. Disco 3? I now have an IIDTool which appears to let me turn it on, but I can't really test it as the current weather is too warm. |
Being an sc would it not have been an option?? Just check for it under the bonnet on the passenger side wing |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
...and you should have a timer option on the touch screen.. ... - .- -.
Ok, dumb question, but what does it look like? |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
The easiest way to tell is like Stan said - look to see if you have the timer function on the screen.
Well I can enable the FBH and the timer screen with the IIDTool, but I am dubious as to wether this allows me to actually use it. I guess I'll check it on my lunch break to see if the exhaust port is there. |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Highly unlikely that an SC has an FBH - they're not generally needed on petrol engines unless you specifically want park heating. |
I do have one on my supercharger but its to warm right now for it to turn on so all I get is the fans running if I turn on timed climate or activate it with the remote control , as other have said it's not impossible that you have it but quite unlikely .
The FBH is standard on diesels as a supplementary heater. Diesels are so efficient that they do not even produce enough waste heat to heat the large RR interior quickly on a cold day so that a additional heat is necessary.
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Hey it's summer (supposed to be anyway). Who cares lol No longer FF owner but still interested. Present car Jaguar XE
