Home > Technical (L322) > Transafe fail prog error please help... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
same here,
28th May 2015 11:02am |
William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 140 |
I had this problem driving me mad anyways I took out the battery after 10mins and found abut of corrosion by the transfer box ecu so i got another ecu plus the harness from transfer box and ecu and also cleaned up the terminals between below the ecu and touch wood everything seems to be ok after 3k miles.
28th May 2015 11:24am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
As well as above, it can do it when the battery starts to fail....
28th May 2015 11:39am |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 |
Thanks, I didn't think there could be anything majorly wrong with the gearbox as over the last 6 months it has only done it 3 times. |
29th May 2015 11:00am |
It trips this fault when the input and output speed sensors don't agree with each other (or a worn battery!!)
29th May 2015 10:59pm |
