Home > Technical (L322) > What's this do? (picture inside) |
Balki Member Since: 13 Nov 2014 Location: Tasmania Posts: 35 |
thats just the water down pipe for the wiper arm area, it should just put the water down to the ground under the vehicle |
4th Sep 2015 2:23pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7634 |
............from the plug you can see top right in your pic.... I'd move it off the battery tray when you put it back....
4th Sep 2015 3:08pm |
alx Member Since: 13 Jul 2014 Location: Beds Posts: 99 |
It's pretty obvious what it does I was more interested to see where it goes as in if it links to something below the battery tray which I cannot remove. That's fine, I've tucked it in behind the battery for now |
4th Sep 2015 3:25pm |
Sorry, I was just answering the thread title.
4th Sep 2015 3:31pm |
That's fine, I appreciate your reply mjdronfield, thank you.
4th Sep 2015 3:34pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Fuel burning heater is standard on Diesels.
4th Sep 2015 6:11pm |
Thanks, that's what I did (looked at the other side) but the hose there is longer than this and appears connected/fastened at both ends. I'll leave it like that since it didn't cause any visible issues until now. |
4th Sep 2015 6:14pm |
