Home > Technical (L322) > CHECK COOLANT LEVEL - WARNING APPEARING EVERY OTHER DAY |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Small leaks only leak when the engine is hot and then usually evaporate before you see any evidence, cleaning off the expansion bottle will tell you if that's the problem...
3rd Nov 2016 11:01am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
My 2004 car had a radiator leak, bottom corner on driver side, it was replaced and no further problems. I was told that this was a common fault. One could see the problem area by unbolting the plastic tray under the front of the car and then sliding underneath with car on high suspension. Only Range Rovers since 1988 |
3rd Nov 2016 3:52pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
These dark evenings may help you if any of the above don't.
3rd Nov 2016 6:01pm |
6029 king Stephen Member Since: 11 Apr 2015 Location: Sittingbourne, Kent Posts: 101 |
I have discovered the cause of the coolant leak. I looked under the bonnet yesterday when the car was running and noticed that there was a fine spray coming out of the side of the coolant bottle, despite being tiny it was running down just below the bottle. This morning, having filled it up last night, I lifted the bonnet whilst the engine was running and noticed that there is an even bigger leak on the underside of the coolant bottle. I have ordered a new bottle and hopefull this will be the end of the coolant leak.
4th Nov 2016 12:34pm |
In that case I think I'd get a length of good quality strong Bowden cable and make it a one piece, then keep an eye on it for fraying...
4th Nov 2016 3:10pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6661 |
Strangely enough, I'm getting this warning every so often. The anti freeze is spot on the top fill level. I've checked the connections on the sensor but it still pops up now and again.
4th Nov 2016 7:18pm |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
Could it be a similar problem to the TD6, or was it sorted out on the later models? http://www.fullfatrr.com/forum/topic20913.html
4th Nov 2016 7:49pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3061 |
@alan
4th Nov 2016 8:05pm |
Yesterday the coolant problem hit a new low when I arrived at work and after turning off, I could hear hissing and gurgling coming from under the bonnet. After lifting it, I discovered that water was shooting out of the side of the coolant bottle and there was a great deal of steam. Later that day, I refilled the system and began my drive home when after only 5-10 minutes the message appeared again. After arrival at home I had the same scenario as that morning. With a new bottle and the bonnet cables on order but not due to arrive until next week, something drastic needed to be done.
9th Nov 2016 10:26am |
Despite many attempts at repairing the tiny holes and crack with a soldering iron to melt the plastic, it worked initially but after a short run into work there would be fluid jetting out of the same place and lots of steam. Fortunately, the parts arrived last week and have been fitted. No problems with low coolant now and what's more, I don't need to use pliers to open the bonnet.
22nd Nov 2016 4:08pm |
I didn't know that, so I'll make sure I add anti-freeze rather than water next time I fill it up! Got - 2017 SDV8 Autobiography in Loire Blue Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
22nd Nov 2016 10:40pm |
lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74 |
I chased this ' fault' for ages, new rad, water pump, 88 degree thermostat mod, new bottle cap. Always lost coolant and was convinced I had a hole in tank as always had damp marks.
25th Nov 2016 12:16am |
Yep the lower temp makes a massive difference to everything...?? Pete
25th Nov 2016 12:49am |
vitola231 Member Since: 07 Jan 2016 Location: london Posts: 44 |
I had same issue, bought new oem bottle and overheated once and saw spray come from tiny little hole also. Somewhere I read to fill 10mm over top fill line. After I did this 10or20mm I never had a problem again. I could make warning light come on by flooring it before, whenever I passed I got warning. |
30th Nov 2016 2:50am |
