Home > Off Topic > Any plumbers? |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
I want to put a tap in my internal garage. The en suite is directly above the garage and I was wondering if I could take a feed off of the cold water tap which runs under the floorboards. |
17th Apr 2017 11:10am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34915 |
i'm not a plumber but i got a feed of the cloakroom toilet/sink cold feed to supply my washing machine in the garage which is adjacent to the cloakroom so your idea sounds like a plan.... ... - .- -.
17th Apr 2017 11:22am |
I did think about the downstairs toilet as it backs onto the garage. I thought the fall from upstairs might assist with pressure though. |
17th Apr 2017 11:31am |
It doesn't matter, the fall won't make a difference as the outlet tap you are fitting is where it is regardless so it's the fall from the header to there. If the downstairs wc is easiest then do that. Do you actually have a header tank for cold water in the loft, if not then all you cold water feeds will be mains pressure in any case so it will be irrelevant.
17th Apr 2017 11:39am |
Yes, there is a header tank in the loft. I could take a feed off that I suppose? |
17th Apr 2017 11:53am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7756 |
Just take a feed from the most convenient place.
17th Apr 2017 12:07pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1071 |
People watching so much porn on the internet is giving them an unhealthy and unrealistic expectation of how quickly they can get a plumber. letters not necessarily in the right order |
17th Apr 2017 12:41pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 895 |
17th Apr 2017 1:03pm |
if you have a header then all your cold taps will be gravity fed apart from the kitchen tap probably. So just take the feed from the WC if that is the easiest.
17th Apr 2017 5:48pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
I put a tap in my garage and also a couple in the garden. I made sure there was a valve to turn it all off and that it can be drained completely, otherwise you may get frozen pipes. |
17th Apr 2017 6:00pm |
