Home > Wheels & Tyres > Tyre sawtoothing |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2213 |
Did you have it 4 wheel aligned on a Hunter system? They tend to be the most accurate by far |
10th Jun 2018 2:29pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7753 |
Are you sure it's not your driving ?
10th Jun 2018 2:49pm |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 |
Hi. Yes to Hunter. We even learnt how to put the car into tight tolerance mode via the brake pedal.
10th Jun 2018 6:56pm |
An explanation ?
10th Jun 2018 8:06pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 586 |
I had vredstein on 20" on mine when i got it they did that just on the front edge .now got toyo on all 4 no probs so far (not off road tyres tho) |
10th Jun 2018 10:05pm |
Thanks for the input. I have considered (improper inflation, excessive toe-in, low-wear applications and taking into account that I check the pressures and have had the car aligned I am resorting to think it is the kind of tyre combined with lots of moderate style driving however the near side is so acute and as it occurred on the previous set partly owned by the previous owner I hoped there was something else I could check ? Anyone else on 22 continental combination experiencing similar ? 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
11th Jun 2018 5:56am |
