Home > Maintenance & Mods (L405) > Check oil level on MY 17 car |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3674 |
I will show you how to check oil level on a 2011 L322, but please ignore this reply if someone suggests it is different on later model L405’s.
28th Jul 2018 7:21pm |
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 |
If it is the same as the MY2014 one you need to enter the car and press the start button without your foot on the brake, then press the menu/ok button on the left of the steering wheel, this will bring up the menu in the centre screen between the rev counter and speedo. Use the arrows to scroll down to the service menu and you should be able to check the oil level from there.
28th Jul 2018 7:27pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3691 |
It’s extremely simple - and very well explained in the manual - you obviously missed it 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
28th Jul 2018 7:29pm |
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 395 |
I thought that's the case but I looked in the manual and couldn't find it in the menu selection at the back.
28th Jul 2018 8:15pm |
0949 Member Since: 01 Nov 2013 Location: Notts Posts: 19 |
When attempting to check the oil level in my L322 on the designated service menu page I get 'not available' even when allowing time for it to settle. Any ideas? |
30th Jul 2018 2:37pm |
Open the bonnet,
30th Jul 2018 2:48pm |
Thanks very much Mike. Do I have to keep the menu display open at the time or start again after following your procedure? |
30th Jul 2018 2:55pm |
Leave it reading “Not available”
30th Jul 2018 3:06pm |
Hold it until display changes.
30th Jul 2018 3:20pm |
Worked like a charm! Thanks again Mike. |
30th Jul 2018 5:26pm |
jumpin mouse Member Since: 28 Feb 2016 Location: North West Posts: 222 |
I'm trying to check the oil level on my MY2015 SDV8 but keep getting the 'not available' message. I believe that I have followed all the instructions in the manual, which are pretty much as in this thread. I've tried it with bonnet both closed and open.
7th Jul 2020 6:23pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4226 |
I’ve heard the sensor sometimes gets damaged by oil ingress to the wiring...sump off job
7th Jul 2020 8:40pm |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 949 |
I’ve given up trying to work out how to do this, despite following the instructions here and in the online manual (my car came without a manual”because it’s on line now sir”) What’s wrong with a dipstick FFS! |
7th Jul 2020 9:02pm |
Dipstick is too messy for most RR owners 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
7th Jul 2020 9:03pm |
