Home > Maintenance & Mods (L322) > Replace Suspension Arm Bushes - What Do You Think?
Page 3 of 3 <123
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
srpara wrote:
That's the cheapest way to do it, only two bushes to replace on the front (each side) just make sure the swivel joints aren't knackered
If the swivel joints are knackered, do I need to replace the whole arm etc, or just get new swivel joints?
Excuse the - possibly - daft questions, as you may have guessed I'm not mechanically minded. What do I put here then?
Post #492385 15th Oct 2018 10:28am
srpara
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
If the joint has gone on the bottom arm then you will need to replace that whole arm, the other swivel joint is a separate item so you would not have to replace the arm with the big bush in it that connects to it.
Post #492432 15th Oct 2018 6:11pm
GAC23
I think - and hope - it's just the bush that's gone.
Thanks for all your help. What do I put here then?
Post #492493 16th Oct 2018 8:43am
GAC23
Is this dealer dishonesty or incompetence?
FF needed an MOT last week,
I put it in for the test fully expecting the bushes to cause a fail. But thought it sensible to see if anything else needed fixing too.
The bushes were logged as 'an advisory': Signs of perishing to both front lower suspension arm bushes.
However, 'suspension arm ball joint excessively worn Offside Front Lower' gave me an MOT failure.
I couldn't wait for the 6 weeks it would take Lookers Chipperfield to fit me in. So I took it to Langley 4x4 instead - they're highly recommended.
With the ball joint replaced, the 'clonking' I'd been hearing was no more.
Why didn't Lookers Chipperfield spot this obvious fault?
Are they simply incompetent. Or - more worrying - perhaps they'd rather me foot a large bill for work which wouldn't solve the problem. What do I put here then?
Post #494012 29th Oct 2018 4:09pm
srpara
Both more than likely Very Happy
Post #494167 31st Oct 2018 12:25am
dirtymonkey38
srpara wrote:
I would replace the bottom ball joint as well while you are doing it but can be a bitch to get out may need to heat it up.
I've just got all the parts to replace mine on both side, all 6 items was under £200 ( Bearmach) but you can get cheaper ones around £120 but I like to use a make that I know
How do you rate the Bearmach suspension parts? any issues fitting etc? 2011 RR Autobiography 4.4 TDV8
Post #500441 3rd Jan 2019 5:25pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
About to replace the top rear bushes on both sides which have started the creaking pram noise at 110,000 and which appear to be the original ones. Finding new replacement concentric bolts, washers and nuts is proving a problem though.
Post #500454 3rd Jan 2019 8:14pm
dirtymonkey38
is that for the rear?
https://www.advancedfactors.co.uk/steering--suspension-52-c.asp 2011 RR Autobiography 4.4 TDV8
Post #500457 3rd Jan 2019 8:23pm
DaveK
Yes, the bolt, nut and washer that is used for the top bush that also adjusts the rear camber. Looks like you have the lot but how come a bolt comes in at £14.00 !
Post #500458 3rd Jan 2019 8:27pm
dirtymonkey38
Listed on Advance Factors
https://www.advancedfactors.co.uk/rear-hub--carrier-289-c.asp 2011 RR Autobiography 4.4 TDV8
Post #500460 3rd Jan 2019 8:32pm
Page 3 of 3 <123
