Home > Technical (L322) > Need a 4.4 TDV8 FBH guru
Page 3 of 3 <123
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Roger,
Usual stuff, fob battery etc you can stick a meter on the unit and see if it has power!
Martin, yes please Smile
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #504646 9th Feb 2019 8:53pm
rjff
I've recently got my fob working again, but cannot rember the T number, is it 90 or 91. however:
What battery do you have in your remote is the first question. There should be one and it should be a CR1/3N
The book says for your receiver the fuse should be number No16, a 5amp one in the rear load space fuse box, offside, behind the removable cover. Fuse is, I think, bottom right near the red conductor connection.
Remove it for several seconds, replace it, press the off button on the remote within 5 seconds for a least 1 second. Release and then press the off button. You should have a continuous red for a few seconds. If it appears slighty orange the battery needs changing in the remote.
Let us know if that does/does not work. Cheers
Richard
Gap IIDBT
Post #504648 9th Feb 2019 9:16pm
drakes
Removing the connector from the reciever (as you did) is the best way to sync. Check fob battery as suggested but mine turned out to be a faulty reciever so if you can find someone else nearby to check your remote against their reciever or the other way round you should be able to find which one is faulty.
T90 and T91 remotes and recievers are interchangeable so someone with either type will do 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #504650 9th Feb 2019 10:09pm
Rog21
England 2012 Range Rover Vogue TDV8 Buckingham Blue
Checked fob battery and that’s okay. Also got power to unit.
After a bit more searching it looks like the remote I have brought a t91r may not work with a l322.
Can anyone confirm this?
Rog
Post #504696 10th Feb 2019 12:41pm
Bushy30
Hi Rog,
Sorry to say from everything I've read it won't -- T90 or T91, but not with the R
Previous: -
Post #504719 10th Feb 2019 4:10pm
drakes
Yes Bushy is correct, the T91R has a digital output instead of analogue 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #504728 10th Feb 2019 6:47pm
Page 3 of 3 <123
