Home > Maintenance & Mods (L322) > Rear Brake Disc's |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Right its payday and I've got my bonus so the FFRR is getting a new set of anchors all round. My rears are very shot and i now have a band round the outside of corrosion/scale. its as if the pads aren't touching the full braking surface. Could someone with the 4.4 petrol let me know if this is correct or has some spanner put the wrong pads in?
25th Mar 2011 7:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
done my fronts recently and got them of ebay, discs and mintex pads for around £70 delivered, rear combos are slightly cheaper.. ... - .- -.
25th Mar 2011 7:16pm |
Did you use standard discs or up rated? |
25th Mar 2011 7:38pm |
just bog standard , and they work really well .. ... - .- -.
25th Mar 2011 8:17pm |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 830 |
Brakes international are pretty good value. My Previous RR's!
25th Mar 2011 8:59pm |
these are the fronts ones i got ...
25th Mar 2011 9:06pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1651 |
I recently (uprated) the discs and pads all round on my P38 and my CLK and wondered about doing it to the FFRR as well. I just got slotted/drilled/grooved discs all round on the P38 and they work great and look good as well.
25th Mar 2011 11:44pm |
slim_sane Member Since: 09 Jan 2011 Location: Kent Posts: 43 |
+1 |
26th Mar 2011 7:29am |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 |
when mine need replacing i'll be going for Brembo drilled/vented discs and Brembo pads
26th Mar 2011 11:46am |
Rear brakes don't work as hard as the fronts, therefore they tend to build up that rusty ring around the edge. Take the vehicle for a drive at 70mph and when there is nothing behind you slam on the brakes hard, do this a few times and the rust should clear off, it will also deglaze the brakes making them more efficient. |
26th Mar 2011 11:51am |
make sure they are the correct thickness nick, they might be different because of the brembo callipers.. ... - .- -. click link for , FORUM WIKI HOW TO Ǝꓕ∀ꓕOꓤ PICS workshop manual downloads are in our wiki . |
26th Mar 2011 11:58am |
thanks Stan - have checked and they are specifically for the 4.4 V8 |
26th Mar 2011 12:19pm |
