Home > Maintenance & Mods (L322) > condensation in rear lights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
best get some goldfish then..... ... - .- -.
6th Mar 2012 5:39pm |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
anyone who doesn't want to drill can try putting in a silica gel pack XYD500010
6th Mar 2012 5:45pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1227 |
One of my lights has shown a little fogging too, I might try the silica option, as long as there is not much water in the casing. Tom
6th Mar 2012 5:52pm |
The only problem with putting silica jel packs in the units is if the leak persists that causes the condensation the silica jel becomes saturated and requires drying to restore it moisture absorption properties.
6th Mar 2012 6:15pm |
think the gel packs were only designed for misting up problem, not full on leak/water in lamp unit You can paypal direct using - www.paypal.me/duckworthparts
6th Mar 2012 6:23pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3689 |
I use silica gel in ammunition and gun cases and recharge them / dry them out every 3 months in the aga overnight |
6th Mar 2012 11:29pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Where do you put the silica gel packs in light as they are sealed? Into where bulbs go? Present :2008 TDV8 HSE
7th Mar 2012 12:33am |
Shropshire lass Member Since: 03 Oct 2011 Location: Shropshire Posts: 58 |
Big help ! Wasn't sure what to do re misting up on drivers side rear lights.
7th Mar 2012 12:42am |
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 |
or they could just make the lights work as they should? Range Rover 4.4 V8 Vogue |
8th Mar 2012 6:25pm |
^^^ couldn't agree more.
8th Mar 2012 7:28pm |
Where do you put the gel packs exactly ? Present :2008 TDV8 HSE
8th Mar 2012 9:09pm |
SupaCharged Member Since: 30 Dec 2011 Location: England, Herts Posts: 29 |
I saw a good tip for this on another car forum, they were using fishing line tied to a silica bag , drop this into via one of the bulb holders and you can remove it as and when you please. |
8th Mar 2012 9:40pm |
