![]() | Home > Technical (L322) > Groaning noise from nearside front after starting |
| Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115
Hi all,
Hmmmm... interesting....
| Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 746
I'm guessing it should be virtually silent .. |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
It will kind of groan on initial startup but then settle down to more of a mini jet engine sound |
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
Its not the heater is it ? mine makes a farting noise when I switch on the car although it farts and groans after I switch the car off too its always done this which leads me to thinking it aint anything serious. Present :2008 TDV8 HSE
| simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650
Sounds like the FBH starting up to me, as Kingpleb has said it quietens down after it has been running for a few minutes. The FBH comes on automatically once the temperature is below 6 degrees (IIRC) to assist with heating the cabin. |
| PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877
My FBH makes the same groaning noise. |
| killatomato Member Since: 14 Jul 2011 Location: Wirral Posts: 41
Yep, mine does that too. But my local garage thinks its the air con on its way out! It does sound silly coming from such a prestige car especially outside the school. |
| Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543
I think you may be confusing a couple of uses of the fbh. It is fitted to all diesel FF's as a quicker means of warming up the car in the colder weather. A secondary use (which is not standard on all models) is for it to come on in advance as a cabin heater when the car is parked up. Mine has the basic fitment and like yours over the last few weeks in the colder weather the car makes the strange "groaning noise" when I start it up. Pretty sure that is what you are hearing. As far as I am aware you cannot turn off this basic feature, although I could be wrong of course. No longer FF owner but still interested. Present car Jaguar XE
| landyash Member Since: 05 Jan 2012 Location: Nottinghamshire Posts: 72
I Olders I have just joined today, Hello all.
Good - sounds like it's the 'normal' noise then ... |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764
Mine sounds like an angry bee for a few minutes! Ash
| Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1531
Groaning mumbling, farting- has the wife eaten any Jerusalem Artichokes?
Sounds like it is the FBH and is relatively 'normal'.
| All times are GMT |
