Home > Technical (L322) > suggestions for tow bar
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Jonte, I take it that you don't need to but the Land Rover Tow module with this kit ?
Does it all work OK as a plug and play ?? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #100385 5th Jan 2012 12:44pm
Johnte
Everything was with the kit, just plugs straight in. If you look at the instructions (linked from eBay site) it shows you what's included, and where to mount everything.
I guess fitting could be done in less than 10 minutes.
To be honest, I haven't actually tried it yet Embarassed I only bought for a bike rack - which I have yet to get..
Post #100391 5th Jan 2012 1:05pm
bogie
wish Id seen that comment before...my Westfalia kit turned up and had the towing ECU in it ....so my new OE Towing ECU is surplus now
good value the Westafalia kit it seems, around £90 inc towing module and everything, will be fitting at the weekend Smile cheers
bogie
Post #100556 6th Jan 2012 9:02pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Now you lot are just confusing me !!
So I need the towbar from someone like westfalia and then a wiring kit?? Total cost over £250..??
Is that right or am I mistaken..
Ta Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #100562 6th Jan 2012 9:32pm
simon1233
Have a look here: http://www.pfjones.co.uk/tow-bars/tow-bars...wbars.html
You pays your money, you makes your choices Thumbs Up
The specific wiring loom they offer should be the westfalia version with the land rover module Thumbs Up
I bought my detachable towbar from these guys, it came with the Landrover logos on it and the storage unit as well Thumbs Up
Post #100576 7th Jan 2012 1:27am
T24RES
Ta
Westfalia is the oem fitted by land rover. They make the metal bits and the wiring kit, fits as intended with all the extras.
http://www.westfalia-automotive.de/index.php?id=home&L=1 search here for the stuff will have fitting instructions in pdf for you to look at, then order from the cheapest source - Towequipe, Pfjones, e-bay, etc.
Post #100624 7th Jan 2012 12:58pm
bogie
yes, got mine from PFjones - westfalia OE dedicated plug play kit for FFRR
you need:
armature + detachable ball bit - £350 ish but OE look when not in use - this is the OE option
or
armature + fixed tow hitch etc (cheaper) £120 but its there permanently stuck out at back of car
electrics kit - dedicated westfalia kit inc Tow ECU - £87 for 7 pin (a bit more for dual/13 pin)
I only wanted to fit a big bike carrier onto the tow hitch, and not worried about having a permanent tow ball, so went for the cheap option - £120+87 all in, then £80 for a 4 bike carrier (Witter) cheers
bogie
Post #100640 7th Jan 2012 3:17pm
